Old 02-13-2004, 10:07 AM   #9541
Herminator's Avatar
Send a message via ICQ to Herminator
Don't worry folks, I'm still around
arn671, how about sending some of that traction to me need more grip on wooden floors although I did manage a couple of rolls on monday I was chasing the pack down in the final and was not sparing an inch of track, unfortunatly road rail corner dots have a nasty habbit of rolling you if you put a wheel on them
Need to check my drive train soon, either my rear diff is extremely gritty (there's no grit indoors just dust) or a bearing or two in the rear right hub has gone tits up
Anyone with an R3 think of or tried using the Yokomo steering posts and fitting the old style steering to replace the rack? Seems to be attracting dirt and binding for a few people. May just need a shorter turnbuckle for between the posts.
Herminator is offline   Reply With Quote
Old 02-13-2004, 01:08 PM   #9542
Hebiki's Avatar
Trader Rating: 26 (100%+)
im gonna slap the old steering from the R2/Yokomo and try it on the R3. im not very happy with the rack right now.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 02-13-2004, 01:12 PM   #9543
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Default Re: Twitchy here i come!
Originally posted by Hebiki
eeyan, thanks for giving dyaz21 the hpi pistons. ill put those into my car tonight. hopefully it'll solve the problem with steering.
cant wait to try out that new one way too. eeyan, ill give u the money for the one way at tamiya on sat.
ling u get my PM?
randman... u going to socal on tuesday. ill be making more changes to the car this weekend. maybe ill finally get the R3 to where i want it.
Yep, I'll be there on Tues, see you then.
Old 02-13-2004, 06:26 PM   #9544
SpeedTech's Avatar
Hi Guys,
The new SpeedWay Pal Aluminum steering rack will be available soon, and that will give the car even more steering throw, which might give the steering some of you are looking for (heibiki )
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 02-13-2004, 06:40 PM   #9545
Cool 1/12 Scale Touring Car
Can anyone tell me if Alex Racing are going to have a 1/12 scale touring car?
flbugboy is offline   Reply With Quote
Old 02-13-2004, 07:42 PM   #9546
Originally posted by SpeedTech
Hi Guys,
Steve Wang
Chris isn't the only person that will be interested to see that Speedway PAL steering rack
Old 02-13-2004, 07:43 PM   #9547
Default Re: 1/12 Scale Touring Car
I kinda doubt they will do one, I think their main focus will be on getting their name out there a bit more before they start making cars for fun classes.
Old 02-13-2004, 08:09 PM   #9548
GTO2's Avatar
R/C Tech Charter Subscriber
let me know the outcome...thanks.
GTO2 is offline   Reply With Quote
Old 02-13-2004, 08:30 PM   #9549
Hebiki's Avatar
Hi Guys,
Steve Wang
its HEBIKI steve... HEBIKI.. not HEIBIKI! hahahaha
got a pink one coming in? i hope so. if you do. consider it bought
i got my hpi pistons from eeyan. so that should help also.
GTO2. im gonna try the new rack first.. if that gives me the steering i want/need i wont switch to the yoke steering assembly.
Hebiki Design Works
Old 02-13-2004, 11:12 PM   #9550
SpeedTech's Avatar
actually, the Alex car would be the easiest I think to have a 1/12th scale touring (if they produce one)
Shorter chassis and upper deck, and shorter center shaft is all you need. You can run the mid span arm in the long span position and I believe that puts you perfect as far as width for a 1/12th scale. Then all you would need are some Yokomo universal bones for their 1/12th scale and I think you're set. I priced out a custom chassis one time...it is way too much to do just one, but if there are enough interest, I can get a quote. Let me know guys
Steve Wang
Old 02-13-2004, 11:12 PM   #9551
SpeedTech's Avatar
oops...sorry!
Steve Wang
Old 02-13-2004, 11:18 PM   #9552
Steve YGM
NismoSkyline17 is offline   Reply With Quote
Old 02-14-2004, 06:06 AM   #9553
Regional Moderator
Hi Guys,
Steve Wang
Nice Steve are you going to be getting the front post also?
PA020 ?
Ko Racer is offline   Reply With Quote
Old 02-14-2004, 09:18 AM   #9554
John_S's Avatar
hi guys im after some setup help my cars rear end is just way to loose in some corners iv increased the width of the back end of the car with shimms between the wheel and thexes and have the camber links in the longest position and even have them shimmed up to try and cancel this out my rear toe is the minimum you can have with the offset balls and my tires were fine i even tryed a new set and they werent any better
any help would be greatly apreciated because iv been trying to get rid of this for a month or 2 and its dropped me from winnin the a to middle of the b final
Thanks guys
John_S is offline   Reply With Quote
Old 02-14-2004, 10:32 AM   #9555
Herminator's Avatar
To make the rear more stable you want more toe in, not less. This will help it track in a straight line.
It's probably into corners you're having problems, so try altering the front end. Stiffen it up so the front isn't biting as hard. You may need to change springs or maybe a small shock position change will do it. Try standing them up a bit more and moving the out on the shock tower and suspension arms.
Try leaning the rears over and going for a softer spring, although not too far from what you use in the front.
If all else fails it's often a good idea to go back to the kit settings. Try the kit setting but with one grade harder spring on the front, it should atleast be reasonably stable indoors.
Generaly if the problem is on the way into a corner you work on the front end and is it's on the way out you work on the rear end, where ever the weight is being transfered to.
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
