Alex Racing Barracuda R2 & R3 >
Like Tree4Likes
Old 02-04-2004, 05:52 PM
  #9376
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Originally posted by Mr. MR4
Randman,
I managed to fit the battery strap on my PAL R2 with some minor modifications using Yokomo Servo Mounts.
Will post some pics soon.
I haven't tried the tape yet but will it hold well in a crash??????
Karl
Straps can be made to fit, but tape is much more secure, I've never ejected a battery while using tape.
Randy Caster is offline
Old 02-04-2004, 08:04 PM
  #9377
highwayman's Avatar
How can i get more on-power and exit steering from my xenon R2? i feel my car has too much initial steering and not enough exit steering... im still running the stock springs.
highwayman is offline
Old 02-04-2004, 08:09 PM
  #9378
29Dennis's Avatar
highwayman: Im not a Cuda expert but how much toe are you running in the front end. To much will make the car turn in good and will push while exiting the corner.
29Dennis is offline
Old 02-04-2004, 08:10 PM
  #9379
JusBox's Avatar
you could increase kick up, increase caster, stiffen the rear springs, use thicker front shock oil, reduce front droop to solve the push on exit. Many options but try one at a time.
JusBox is offline
Old 02-04-2004, 08:14 PM
  #9380
highwayman's Avatar
im running zero toe in front.
Old 02-04-2004, 08:18 PM
  #9381
highwayman's Avatar
... wouldn't increasing kick-up and/or caster increase my initial steering more and even reduce exit steering? that's why im using the stock c-hubs, although i have a stage 3 xenon upgrade, i think the red alum xenon c-hubs have a 7 degree caster.
i'll try to play with the springs first, stiffen the rear as you suggested. - thanks.
Old 02-04-2004, 08:22 PM
  #9382
Increasing caster will give less initial turn in.
Old 02-04-2004, 08:23 PM
  #9383
JusBox's Avatar
Well by increasing kickup, you're reducing the amount the front will squat and reduce weight transfer to the front. It reduces turn in due to increased camber but once the car gets in the corner the extra camber might give you more steering throughout the turn.
JusBox is offline
Old 02-04-2004, 08:46 PM
  #9384
highwayman's Avatar
ok. thanks. will try it out.
Old 02-04-2004, 08:49 PM
  #9385
Hebiki's Avatar
Trader Rating: 26 (100%+)
wow my problem is opposite. i have no initial turn in.. (it pushes off power.) but plenty of mid corner and on power steering.
care to share your track conditions and set up?
Hebiki is offline
Old 02-04-2004, 08:52 PM
  #9386
JusBox's Avatar
Hey bud, there's a lot you can do to decrease off power push... what have you tried?
JusBox is offline
Old 02-04-2004, 08:53 PM
  #9387
He's running the Xenon R2, so the car will be way different. I'll take a look at your car, and can make some suggestions. Or if you see Steve at SoCal on Sat, hit him up.
Old 02-04-2004, 08:57 PM
  #9388
Hebiki's Avatar
R3 seems to behave differently from my R2... i havent experiemented with much.. but right now. im on the second hole for front and rear shock towers.. starting from the outside counting in.
i do have the front kicked up.. so mid corner and exit steering is where i like it.
Hebiki is offline
Old 02-04-2004, 09:03 PM
  #9389
SpeedTech's Avatar
Heibiki,
If you want more turn in, then take out the shims underneath the front suspension arm. If you want even more turn in, angle the front arms by putting shims underneath the rear set of arm pivot balls on the front arms. Sometimes, an off-power push can be from going into a turn to fast, and trying to make the car turn at speeds that the tires can not perform.
Basically, a car that's going straight, wants to keep going straight, and the friction between the tire and the ground is what makes the car turn. However, the more speed you're carrying, the more force is behind the car, therefore, there comes to a point where no matter what your setup is, or what tires you're using, your car is still going to feel like is pushing...but it's simply not slowed down enough to negotiate the turn.
I'll be there Sat., and I'll spend some time checking out your car on the track
Steve Wang
SpeedTech is offline
Old 02-04-2004, 09:04 PM
  #9390
JusBox's Avatar
Maybe try a softer front sway bar (if you have one), thicker rear shock oil or softer front springs? Can try increasing rear droop too.
JusBox is offline
