Alex Racing Barracuda R2 & R3 >
Old 01-26-2004, 10:28 PM
  #9076
Hebiki's Avatar
Trader Rating: 26 (100%+)
Hebiki is offline
Old 01-26-2004, 10:29 PM
  #9077
Hebiki's Avatar
Hebiki is offline
Old 01-26-2004, 10:30 PM
  #9078
Hebiki's Avatar
Hebiki is offline
Old 01-26-2004, 10:31 PM
  #9079
Hebiki's Avatar
Hebiki is offline
Old 01-26-2004, 10:32 PM
  #9080
Hebiki's Avatar
#6.. last one..
Hebiki is offline
Old 01-26-2004, 10:39 PM
  #9081
madjack's Avatar
Trader Rating: 25 (100%+)
Post
Originally posted by Hebiki
So does this mean you will be running 19T this weekend at So Cal?
madjack is offline
Old 01-26-2004, 11:13 PM
  #9082
SpeedTech's Avatar
Hi Guys,
Those R3s are looking good. Most of the hop-ups for the R2 will fit the R3 (for example the aluminum dog-bones, the Ti-Axles, these are all interchangeable).
We are currently revamping the Alex Racing USA website, brand new look coming soon (I know, waaay over due ) Should be up by the weekend!
Steve Wang
SpeedTech is offline
Old 01-27-2004, 12:50 AM
  #9083
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
You might want to switch to steel front dogbones, aluminum wont hold up for long I dont think. Looks awesome otherwise.
Randy Caster is offline
Old 01-27-2004, 01:30 AM
  #9084
Regional Moderator
long as a wall doesnt jump in your way your ok
Ko Racer is offline
Old 01-27-2004, 08:23 AM
  #9085
Regional Moderator
here is a good tip for the R3 builders makes the steering rack much smoother !
Ko Racer is offline
Old 01-27-2004, 08:48 AM
  #9086
GTO2's Avatar
Suppose to eliminate the resistance in mid throw of the rack?
GTO2 is offline
Old 01-27-2004, 09:08 AM
  #9087
Regional Moderator
correct the rack it self fits snug on the bushings filing some material off makes the rack glide back and forth better!
Hoping steve finds some bearings for the steering I see they have switched to them in japan already
Ko Racer is offline
Old 01-27-2004, 09:44 AM
  #9088
rc-zombies's Avatar
Originally posted by weaponx
Ko if you can could you weigh the titanium driveshaft and aluminum dogbone against the stock parts and post the figures. Thanks
weight of the axles alone:
Stock front-4.91grams each, Ti front-2.73grams each
Stock rear-5.33grams each, Ti rear-2.99grams each
+/- a few grams...
rc-zombies is offline
Old 01-27-2004, 09:52 AM
  #9089
RcMonk's Avatar
For all you R3 owners, do you think the new pal type drive
system will fit an R2 ? I am waiting for Steve to restock
the Speedway pal drive but if the R3 one fits I may wait
till these come in. Looking at the recent pics of R3 it
looks like it will fit.
RcMonk is offline
Old 01-27-2004, 11:00 AM
  #9090
Herminator's Avatar
Won't work on the R2 topdeck. The R3 motor mount mostly hangs from it's top deck, the R2's motor mount sits on the main chassis, including the Speedway PAL version.
Herminator is offline
