Alex Racing Barracuda R2 & R3
#8941
R/C Tech Elite Member
Originally posted by Ko Racer
yeah thought I would try one out
heath........ I cant tell you eveything now im just going to see how it does . everyone says parts are everywhere for this thing so that is a plus .but the R3 is going to be at the track so dont worry .
#8946
Originally posted by AWOLsoldier
Well i'm going to order a few parts... would you say buing two aluminum shaft supports is better than getting a pal system? Other than the supports i'm picking up the short steering posts and a few odds and ends.
#8947
Originally posted by Randman
The alloy shaft mounts arent better than the PAL system, and the PAL system isn't better than the alloy shaft mounts. They kind of work together to bulletproof the drivetrain though.
#8949
Originally posted by TFR
I think its a Nosram Dominator Power or the new Evolution.
M-Troniks Cirrus is cheaper still in the UK and even nicer M-Troniks website has been completely overhauled, looks very nice now and has info on the Cirrus
pimping over
For stock racing alloy shaft holders and 48dp gears works well
Just make sure your main drive shaft is straight every now and again, the graphite shaft can move slightly in the alloy end pieces and cause spur wobble. A good way to check for straightness is roll it along a flat table with the spur mounting bits just off the edge of the table of course.
justinalamode- try doing a post based search, it's a question answered many times now in this thread. In short there is very little difference, it almost a choice between sparkly graphite or easy access spur gears.
#8950
Does the R3 comes with lightweight aluminium driveshafts or not? What are the items that can be lightened for the R3 as regarding rotating mass?
#8951
Pretty much the same as the R2, PAL hollow drive shaft, aluminium bones, titanium axles, revlite wheels, titanium pinions and lightweight spur gears.
You pays the money you can really go to town.
#8952
it is the same speedo as the lrp quantum comp 2, just in red.
#8953
Re: Re: rayspeed springs
Originally posted by linger
TC3:
A while back, I posted a spring rate chart for all Alex springs, Rayspeed springs, Yokomo Springs and AE springs.
The Rayspeed Red is 18.26 lb/in. The Alex 1.5 x 6.0 is close at 18.52.
The Rayspeed White is 17.17. The Alex 1.5 x 6.25 is close at 17.09.
The stock R2 springs (1.4 x 6.0) is kinda soft at 14.39 lb/in.
TC3:
but there is no chart for the alex springs
#8954
There's hollow graphite drive shaft but I believe it will only withstand upto 19T motor power. Correct me if I'm wrong.
I use TA 1/8 lightweight balls for the diff as well.
