Alex Racing Barracuda R2 & R3 >
Old 01-19-2004, 01:31 PM
  #8866
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Re: R2 and R3
Originally posted by OVA
How do you likr your R3 compare the R2
i havent picked up my R3... cant pick it up until i sell the R2 or friday of this week. whatever comes first.
the new steering rack is gonna be interesting. ill let you know once i build it and race it.
Hebiki is offline
Old 01-19-2004, 03:27 PM
  #8867
Herminator's Avatar
I'm back from racing tonight aand tried the popular rayspeed reds and whites for the first time. They worked very well. Helped by a nicely swept track which meant everyone had plenty grip. The top guys all managed atleast one good run and it was pretty close. I had a good run with practicly no real mistakes and at the time it put me second on the grid. Then in the last run I had to change tyres, as I was on borrowed narrows I put my bald narrows on and didn't like the change, the rear end was too twichty. Two others improved though and put me down to 4th, but there wasn't much in it. Went to wides for the final, which were smoother, although not quite as stable as the borrowed set.
Had a couple door banging's with 2nd to 5th placed cars at the start of the race then settled into 3rd for the rest of the race. With minor changes the car will be good on wides and I've got new narrows coming soon
The rayspeed reds and whites really work well for overall balance of the car
Used my Fuku's in the final, no drop off during a race is great, discharged them at 20amps after the race, they still had around 1950mAh in them I could easily run two races with them.
Next week I'll be a touch faster if I actually bother to clean my motor before I go racing
Herminator is offline
Old 01-19-2004, 04:08 PM
  #8868
Gazza_D's Avatar
Told you Reds and Whites worked good!!!!
To answer an earlier question, i used a tc3 collar in an emergency to get me by, was not quite right but it got me by ok.
Enough to get 6th at BTCC at Ashby. Not bad considering
Gazza_D is offline
Old 01-19-2004, 04:22 PM
  #8869
Herminator's Avatar
I managed to get the super glued screw out of the collar thing needed a bit of reflattening of the rim though My alloy c-hub is a bit scratched now though
Will have to order some spares as I know I'm going to loose one some day
Old 01-19-2004, 04:23 PM
  #8870
RcMonk's Avatar
I have used the HPI Black Flange Pipe 3x4.5x5.5" which seems to be the size as the ones used by the R2. The part number is A838. Any one with a Pro3 or Pro2 should have these. Hope that helps.
Originally posted by Herminator
Does anyone know of a car that uses the same sized little top hat shaped tubes for the cub hub and king pin? Could really do with borrowing one tomorrow if I know someone with a car that uses the same sized part.
RcMonk is offline
Old 01-19-2004, 04:32 PM
  #8871
Gazza_D's Avatar
Does anyone know where I can get a copy of the picture Dave (JDM who) put on the board re shimming the cuda, the one with the two types of bevel gear on it.
Dave where are you.......help!!!!!!
Gazza_D is offline
Old 01-19-2004, 04:38 PM
  #8872
Herminator's Avatar
I wonder what you want that for
try doing a post based search with JDM as the poster and a few words which he's likely to have used. Like shimming, input gears, etc.
Old 01-19-2004, 04:50 PM
  #8873
Gazza_D's Avatar
Wanted a picture to go with the spiel ive written, based on Dave's, I think it was on the other cuda thread though, have tried to find it but it doesnt appear to be out there anymore
At least interest in the Cuda appears to be on the up in the UK now we hva our own forum.
Pity we didnt get the mod job though
Gazza_D is offline
Old 01-19-2004, 05:07 PM
  #8874
Herminator's Avatar
whats this we business
The admin favours the distributer for mod jobs, but Dan at Planet RC also asked Rob to put me on as he may not be around for long periods.
Was the speil I posted about shimming not good enough?
I'm still waiting to get some shims myself, took a while for the shop to get them I've got a really noisey bevel gear in the front at the moment, had one in before and the car was really nice and quiet, one gear change and it's back to the loudest thing on the track definetly needs a few shims in it.
Old 01-19-2004, 09:23 PM
  #8875
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Default Re: Re: Re: Purple R2
Originally posted by Hebiki
thanks for the endorsement randman!
No problem at all
Randy Caster is offline
Old 01-20-2004, 05:05 AM
  #8876
Mr. MR4's Avatar
Hi all,
I know this has probaly been asked before - but where can I get instructions in English for the R3.
I'm waiting to recieve my R3 next week - Any tips for building??
Karl
Mr. MR4 is offline
Old 01-20-2004, 05:12 AM
  #8877
Herminator's Avatar
You can't get instructions for the R3 in english yet.
I'll hopefully have some for the R2 soon though, will need to get them scanned into the pc though.
Old 01-20-2004, 05:55 AM
  #8878
alch's Avatar
Originally posted by Mr. MR4
Hi all,
Karl
If you post the Japanese instructions i can translate it for you..
Alch
alch is offline
Old 01-20-2004, 06:59 AM
  #8879
Mr. MR4's Avatar
Alch
Thanks Alot
Ypu'll be hearing from me soon then
Karl
Mr. MR4 is offline
Old 01-20-2004, 09:28 AM
  #8880
Regional Moderator
ImGoinRCn's Avatar
Hi all,
Karl
this is just an online translator, hope this helps a little.
http://babelfish.altavista.com/
ImGoinRCn is offline
