Old 01-18-2004, 12:41 PM   #8836
Gazza_D's Avatar
Send a message via Yahoo to Gazza_D
I use HPI piston #2, no drilling required....much easier
Gazza_D is offline   Reply With Quote
Old 01-18-2004, 12:45 PM   #8837
JusBox's Avatar
I can't buy those in my area (no good hobby shops) so i'd rather drill.
JusBox is offline   Reply With Quote
Old 01-18-2004, 12:55 PM   #8838
SpeedTech's Avatar
Hi Guys,
We will be receiving our next shipment of parts next week (around Thurs/Fri.) and we should have some of those titanium axles in stock. As soon as I can figure out the pricing on them I'll have them online.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 01-18-2004, 06:00 PM   #8839
Send a message via AIM to R/C Anonymous
my setup from Trackside Novak race in the rubber tire class....1st place B main....this setup sure needs work but its a start...
Front:
shock location out on top and bottom
70 weight oil; stock pistons
ride height at 5 mm
camber at -2
camber link in middle on deck and upper hole on hub
Rear:
shock location middle on top and outer on bottom
xenon hubs with one of them spacers on top that u get with the hubs(forgot how tall they are)
camber at -2
60 weight oil; stock pistons
ride height at 5 mm
camber in middle on deck
Misc:
i had the xenon kit and aluminum rear hubs
i ran the diff in front and back but i think it woulda been better with the one-way since i usually run faster with it
two 1/4 ounce weights outside the motor on bottom chassis
hand-out CS27 takeoff tires
i had alot more work to do to the setup and not enough time to do it....i was running about 3 tenths a lap slower then the top guy in the A main
so yea if u wanna try this it works great for super high traction and dont forget to add some glue to the outside of the tires to help prevent traction rolling
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 01-18-2004, 07:01 PM   #8840
GTO2's Avatar
R/C Tech Charter Subscriber
Thanks for sharing the setup.
May I know what's the track temperature, springs?
GTO2 is offline   Reply With Quote
Old 01-18-2004, 07:32 PM   #8841
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
R/C Anonymous I wonder if your car would work a little better if you used lighter shock oil. I looked at alot of different setups and it seems most don't use over 50wt if they run rubber tires. I looked at alot of TC3 setups for asphalt with rubber tires and they run lighter oil. Maybe this would help.
ST Racing Concepts (STRC)
Old 01-18-2004, 08:06 PM   #8842
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by AWOLsoldier
What's everyone drilling the stock piston to? I picked up some dremel drill bits that come with a 1.2 and a 1.6. If I recall people have been using the 1.2. Any confirmation on this?
3 1.2mm holes. Or you can go with Rayspeed #3 pistons.
Old 01-18-2004, 08:09 PM   #8843
Herminator's Avatar
Send a message via ICQ to Herminator
wyd's post made me look at that setup again and
oil that heavy with the stock pistons sheesh thats some tough dampening. 60-70wt is the upper limit for most with fairly average to large sized piston holes but with the small holes on the stock pistons most go a lot lower in weight.
Herminator is offline   Reply With Quote
Old 01-18-2004, 08:19 PM   #8844
Herminator - Thanks for the help with the chassis, but I think I'm gonna wait for the new one to be released, just much more cost effective, and propably the same result...
Old 01-18-2004, 09:06 PM   #8845
Herminator's Avatar
Does anyone know of a car that uses the same sized little top hat shaped tubes for the cub hub and king pin? Could really do with borrowing one tomorrow if I know someone with a car that uses the same sized part.
Old 01-18-2004, 09:52 PM   #8846
Hey Steve,
Will you be getting anymore Xenon stage 2 kits in red? I'll hopefully be selling my tmaxx tomorrow and i'll have the money. Just wondering if you will have some more soon.
Thanks Brandon
NismoSkyline17 is offline   Reply With Quote
Old 01-18-2004, 10:21 PM   #8847
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
i lost one outta my car before. i think i substituted a Tamya one, fit right in.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 01-18-2004, 10:35 PM   #8848
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Default R2 oneway diff
Anyone here have four bearing R2 oneway diff for sale ? I just happen to have a bad one needle bearing fell out)
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 01-19-2004, 12:03 AM   #8849
Im sure Steve could get a double 1 way diff for ya.
Old 01-19-2004, 12:11 AM   #8850
Herminator's Avatar
come on randman, you've had 90% of the cars out there, you should know several answers to my problem
How about the Yoke SD? or X-Ray?
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
