Alex Racing Barracuda R2 & R3 >
Like Tree4Likes
Old 01-05-2004, 10:25 AM
  #8401
GTO2's Avatar
Default Re: Re: STOCK R3 out of the box
Originally posted by Randman
I definately like the front bumper brace they added, looks like it'll make the front end very strong...
What's up with the shim under the motor mount, is that needed?
It's in the manual...
there will be a 0.5mm gap if without the shim/washer.
I heard some people don't even bother to mount the bottom screw.
GTO2 is offline
Old 01-05-2004, 10:26 AM
  #8402
MikeR's Avatar
Trader Rating: 15 (100%+)
You planning on getting an R3 Mike?
I just got the Xenon stage 2- does that count as the R3?
MikeR is offline
Old 01-05-2004, 10:27 AM
  #8403
Regional Moderator
Default Re: Re: Re: STOCK R3 out of the box
Now that doesnt sound like a good ideal not putting the screw in the bottom
Ko Racer is offline
Old 01-05-2004, 10:29 AM
  #8404
GTO2's Avatar
It makes the whole motor mount block hanging on the upper deck. Not sure too if it's a good Idea to do that, just overheard.
GTO2 is offline
Old 01-05-2004, 10:39 AM
  #8405
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
I wonder why they didn't mill the motor mount to the correct size???
You could leave out the bottom screw if you wanted to get more flex, but you may hurt the gear mesh like the R2.
Randy Caster is offline
Old 01-05-2004, 10:40 AM
  #8406
Close enough man... I dont know if I would like the TC3 steering over the Yokomo steering, I think the R2 will be a little better in that dept.
Old 01-05-2004, 10:43 AM
  #8407
rc-zombies's Avatar
Without the motor mount screwed to the bottom of the chassis...I think it may twist the upperdeck due to the motor weight on one side..... my 2 yens.....
rc-zombies is offline
Old 01-05-2004, 10:45 AM
  #8408
Hey Ramon, will you be at Stockton on Friday for practice. Do you know if you'll be able to get an extra can of tire sauce?
  #8409
rc-zombies's Avatar
the Pro4 steering looks pretty trick... has bearings on the ackerman graphite link.
See page 12 of the manual:
http://www.hpiracing.co.jp/contents/.../download.html
Old 01-05-2004, 10:50 AM
  #8410
rc-zombies's Avatar
Right now it's about 90% sure I'll be there on Friday. sorry no sauce...working hard in getting some.... Billy From Speedworld has them in stock...and he will be racing as well.... I've contacted him already to bring a couple cans.... his shop is closed 'til thurs AM. Worse comes to Worse... I'll personnally drive down to Speedworld Friday morning and pick them up then head down to Stockton....
don't forget to bring a pit table and extension cords....
Old 01-05-2004, 10:51 AM
  #8411
GTO2's Avatar
Default Re: Re: Re: Re: STOCK R3 out of the box
hmm wonder why...last minute findings?
I will stick with the bottom mounting.
GTO2 is offline
Old 01-05-2004, 10:57 AM
  #8412
That is very nice, I have similar on my RS steering...
Old 01-05-2004, 10:58 AM
  #8413
I thought they provided pit tables??
Old 01-05-2004, 10:59 AM
  #8414
Default Re: Re: Re: Re: Re: STOCK R3 out of the box
I havent seen that shim in any of the R3 pics, so I doubt it's last minute findings...
Old 01-05-2004, 11:01 AM
  #8415
rc-zombies's Avatar
If they are not used by the county fair facility...there should be tables and chairs...75% of the time they are available...
it's been a while since I've been to Stockton...you may want to confirm with MO.
