Alex Racing Barracuda R2 & R3 >
Old 01-04-2004, 11:16 AM
  #8356
Regional Moderator
Default Re: Re: R3 looking good
Originally posted by Randman
I knew ya had em somewhere
Ko Racer is offline
Old 01-04-2004, 11:22 AM
  #8357
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Originally posted by Ko Racer
there at the photo shop now hope to pick them up monday
i will show you a few when i get them back
Did you get your R3 already?
Randy Caster is offline
  #8358
Default Re: Re: Re: R3 looking good
Very nice, but it looks like the shock tower will still have to be removed to get it on.
Old 01-04-2004, 11:45 AM
  #8359
Herminator's Avatar
good pic there KO, looks like there isn't the option of mid span arms though, with the rear of the chassis cut away like that.
Herminator is offline
Old 01-04-2004, 11:56 AM
  #8360
JusBox's Avatar
Still not sold on the sparkle chassis but looks nice. I'd like to hear some opinions on the car compared to the R2 as i'm still leaning towards the R2.
JusBox is offline
Old 01-04-2004, 01:06 PM
  #8361
OVA
OVA's Avatar
Trader Rating: 82 (100%+)
herminator
Got me thinking about R2 just might be a better car to get
not better but easy car to work on...
OVA is offline
Old 01-04-2004, 01:46 PM
  #8362
Default batteries
hey fellas, my r2 with the hop up chassis has slots for battery tape only to hold in the batteries, but from side impact in carpet racing my batteries keep hitting my drive shaft. has any one thought of putting a little bar down the middle to keep the batteries from being moved around or is there another remedy? ty
chefmo88 is offline
Old 01-04-2004, 02:01 PM
  #8363
OVA
OVA's Avatar
Wow batteries hitting drive shaft Maybe you should slow down and drive with smart. ask any of the fast guy they'll tell you the same thing take your time to learn to get around the track
PS if you taped it good then the should hold down the battery.
The tape doesnt hold down very well from high impact Good luck
OVA is offline
Old 01-04-2004, 02:20 PM
  #8364
pucho's Avatar
How thick is the chassis on the R3? 2.5mm?
pucho is offline
Old 01-04-2004, 03:10 PM
  #8365
Gazza_D's Avatar
chefmo88
Silly question, but have you chamferred the edges of the battery slots? Helps the cell sit in nice and low, I also did the outside end as GP calls a bit bigger and this helps them sit in there a lot better. Shouldnt have any problems after that. I have modified my car to take an XRay 6 cell battery holder and that works a dream.
Gazza_D is offline
Old 01-04-2004, 03:28 PM
  #8366
Herminator's Avatar
As Gaz says, make sure your slots are chamfered well and make sure you tape them down tightly. What chassis have you got? On the Xenon chassis there is an extra hole meant to be used by the standard motor mount. You can take a servo mount block and put it there in the center of the chassis to help stop the cells from moving inwards. Or if you have another chassis you could drilll a hole a little further forwards to do the same.
I've never had any problems when using tape though.
Old 01-04-2004, 03:52 PM
  #8367
Regional Moderator
No Sir.............no R3 here!
Ko Racer is offline
Old 01-04-2004, 04:30 PM
  #8368
Gazza_D's Avatar
Seems like GTO2 and Dave (who else) are the only ones with their R3's at the mo
Happy with my R2 at the mo and theres not that much difference between that and an R3 anyway. Just the rack type sterring from what I've seen. Sent a PM to Dave to find out all the little changes, but he seems to be working far to hard of late to be natural. Promotion board soon Dave????
Gazza_D is offline
Old 01-04-2004, 05:05 PM
  #8369
Give it a little time, it'll propably grow on ya
Old 01-04-2004, 05:06 PM
  #8370
Default Re: batteries
Get some of the Tobee Craft cell seperators for the SD, drill a couple holes, and they'll solve your problem.
