Alex Racing Barracuda R2 & R3 >
Old 12-14-2003, 06:27 PM
  #7906
justinalamode's Avatar
k randman, thanks for the help once again
i was thinkin about gettin one, so yea. do you think the price will be higher or lower than the estimated 320?
justinalamode is offline
Old 12-14-2003, 06:32 PM
  #7907
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
I honestly wouldnt have any clue what the price is going to be. If Steve doesn't know, then there's no way for him to pass that info on to me. We'll know in a couple weeks though
Did you sign up for the preorder to reserve one in the first batch?
Randy Caster is offline
Old 12-14-2003, 06:44 PM
  #7908
Default first batch ... pink ... MMMm
do they charge your already for the payment?
randman, do you have AIM ? i wanna talk to you more.
Old 12-14-2003, 06:57 PM
  #7909
Default Re: first batch ... pink ... MMMm
They wont charge for payment until a price is confirmed, and the cars are in, or on their way. I am i2andman on AIM, but usually just use PM's because AIM freezes my cpu...
Old 12-14-2003, 07:11 PM
  #7910
alch's Avatar
It is 29900 Yen at RC Champ..
alch is offline
Old 12-14-2003, 07:16 PM
  #7911
My guess is our price will be right around there...
Old 12-14-2003, 08:43 PM
  #7912
Trader Rating: 1 (67%+)
Hi guys..
I need some advice on what spring, shock oil and roll bar to start with if I run on low traction and bumpy asphalt tight track. By adding 1mm shim on the back of front arm, does it increase the car off power steering?
Thanks.
TxMan is offline
Old 12-14-2003, 08:56 PM
  #7913
Originally posted by TxMan
Hi guys..
Thanks.
Check the alex USA site for setup sheets, use a SoCal no swaybar setup for a nice starting point.
Old 12-14-2003, 11:29 PM
  #7914
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Toys for Tots Race
dang my barracuda was awesome today!
thanks for your help Steve!!!! He wrenched on it in between qualifying rounds and my car was so much faster. too bad we had to drive in the rain, which was fun!
im gonna have to buy Steve some jack in the box! the drivetrain is so much freer now!
Hebiki is offline
Old 12-15-2003, 01:13 AM
  #7915
Regional Moderator
ImGoinRCn's Avatar
Originally posted by protc3
shwing.nice bike bro.i gave up riding bikes when i moved to florida.it is the land of old farts.after my first 2 weeks here i almost got killed 4 times by cars driven by a white puff and knuckles
white puff and knuckles...lol
ImGoinRCn is offline
Old 12-15-2003, 01:55 AM
  #7916
Fatboy Joe's Avatar
Hi guys..
Thanks.
This is my basic set up for bumpt tight tracks:
FRONT-
Shock oil: 20wt
Camber: -1 degree
Spring: stock (kit supplied) it's a 1.4 x 6.0
Shock position: all the way out
Droop: 3mm
Ride height: 7mm (our track is really bumpy)
Kick-up: No kick up
Camber link position: stock position
Toe-in / Toe-out: None
Caster: 5 degrees
REAR -
Shock oil: 20wt
Camber: -1 degree
Shock position: 2nd hole from outermost position
Droop: 3mm
Anti-Squat: 1mm shim in the front pivot ball of the rear arm
Toe-in : 2.8 degrees
I am sure the track where I run on is bumpier than your track and this setup works for me alot. You can afford to have on=power steering with the R2 no matter how tight the track is. The car is really great and you can afford to be very aggressive with this setup. I don't use sway bars because they are useless (IMHO) in bumpy tracks.
Good luck!
Fatboy Joe is offline
Old 12-15-2003, 06:15 AM
  #7917
Regional Moderator
You work for speedtech now or something
Ko Racer is offline
Old 12-15-2003, 06:17 AM
  #7918
Regional Moderator
Default Re: Toys for Tots Race
I guess your going to hang on to it now ? Nice to hear you had a great day with the cuda
Ko Racer is offline
Old 12-15-2003, 06:19 AM
  #7919
Regional Moderator
Originally posted by R/C Anonymous
i know this has been asked many many times but can someone post a good setup or refer a link to one for the R2 for carpet medium grip and takeoff 27's...i should have mine up and running so i can some practice in b4 the Novak racein Milwaukee
PS can they tell me the spring weight in pounds and not colors cuz i got my R2 hooked up with AE springs
I found a set up from one of the magazines I just got from japan and there running sorex 28's on carpet so I will see if I can make enough out of it to post the set-up they used ?
Ko Racer is offline
Old 12-15-2003, 06:36 AM
  #7920
Turbonium's Avatar
Trader Rating: 27 (100%+)
please do! i am heading for a carpet race in Jan. and have no idea where to start for the rug...
Turbonium is offline
