Old 12-11-2003, 10:36 PM   #7861
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by rc-zombies
yes...
Well... it should be.
Old 12-11-2003, 10:37 PM   #7862
Originally posted by Herminator
2.4375 is the internal ratio
yes 64dp should be ok on the R3, especially if you buy alloy shaft holders too
On the subject of 64dp gears, what size spur do most of you use? Still in half a mind to swap over from 48dp and would like to work out how many pinions I'll have to buy to cover the same range I have now.
I use 94 tooth spur gears, pinions from 24-38
Old 12-11-2003, 10:51 PM   #7863
Default Droop for the R2
what should I set the front and rear droop to on the R2
Jim C
JIMC is offline   Reply With Quote
Old 12-11-2003, 11:07 PM   #7864
Default Re: Droop for the R2
Jim C
A good start would be 3mm or so, I measure that by going 3mm higher than ride height.
Old 12-11-2003, 11:09 PM   #7865
Thanks!!!!!!
Old 12-11-2003, 11:14 PM   #7866
Thanks!!!!!!
NP, shoot any more questions you have.
Old 12-12-2003, 07:44 AM   #7867
Regional Moderator
R/C Tech Charter Subscriber
Originally posted by JDM_DOHC_SiR
I haven`t recived it yet... I really think that my mail system is really [email protected]@d up over here .... and I have about 200 or so PM`s that I am reading right now since I have not been on the page for a while
-Dave
Ok bro I guess I will get it back for a second time
Let you know if it does end up back here.
Ko Racer is offline   Reply With Quote
Old 12-12-2003, 07:49 AM   #7868
Regional Moderator
Default Re: Final drive Ratio for the R2
How do I go about calculating the final drive ratio for my cuda.
Its been suggested to run 6 - 6.50 final drive with rubber tires stock
Jim C
this might help you out a bit
http://www.arroyoc.com/index.cfm?fus...utilities.gear
Old 12-12-2003, 07:52 AM   #7869
Regional Moderator
Originally posted by Paul_Kultcha
How many people here run 48pitch on their Cuda's and how many run 64pitch?
Do you run 48pitch on asphault and 64 on carpet?
I have been running 48 on carpet and asphalt and its as smooth as the 64 IMO and I run the Pal A-spec kit
Old 12-12-2003, 10:27 AM   #7870
John_S's Avatar
hey guys do you know if any other brands rear knuckles fit on the r2 eg yokomo
John_S is offline   Reply With Quote
Old 12-12-2003, 11:34 AM   #7871
I dont know that anyone has tried, but I know that the hingepin holes would need to be reamed out at the least. The offset may not be right either.
Old 12-13-2003, 03:19 AM   #7872
McLaren's Avatar
The Barracuda R2 or R3, do they come ready with titanium stuff, lightweight stuff, etc or you have to buy such hop ups seperately?
McLaren is offline   Reply With Quote
Old 12-13-2003, 04:52 AM   #7873
Herminator's Avatar
Send a message via ICQ to Herminator
You have to buy titanium stuff seperatly. Mostly it would be for show though as the stock Cuda is pretty light and you'll probably have to add weights to be race legal anyway.
If you really like titanium (like me ) then the first thing I'd replace are the screws, I really don't like the philips head screws on any car, too easy to strip the head on a tough one.
You can get a titanium screw set for a reasonable price and it includes a nice driver.
Other titanium bits available are turnbuckles and axles, axles aren't cheap though but they do lighten the most important thing to lighten, ie. the drivetrain
Herminator is offline   Reply With Quote
Old 12-13-2003, 06:24 AM   #7874
Who makes titanium axles now, they werent avalible when I was driving the R2...
Old 12-13-2003, 06:52 AM   #7875
Herminator's Avatar
Xenon make them, been available since around September, so you had an R2 at the time....
Nice and light and shiney too
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
