Alex Racing Barracuda R2 & R3 >
Like Tree4Likes
Old 12-11-2003, 05:06 PM
  #7846
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by cHckbOY5
dave, i still didnt get the package
it`s coming
-Dave
JDM_DOHC_SiR is offline
Old 12-11-2003, 05:07 PM
  #7847
Herminator's Avatar
Originally posted by JDM_DOHC_SiR
it`s coming
-Dave
so is santa
Herminator is offline
  #7848
Originally posted by Randman
Speedtech has their cuda stuff back in stock, just order from Steve...
naw it`S not like that... I just gave hime some free stuff
Old 12-11-2003, 05:16 PM
  #7849
Regional Moderator
SOOOOOOOO..... Dave did you get the pkg I sent you for the second time???And I havent received yours yet either!
If you would read your pm's I wouldnt have to post here
Ko Racer is offline
Old 12-11-2003, 05:25 PM
  #7850
I haven`t recived it yet... I really think that my mail system is really [email protected]@d up over here .... and I have about 200 or so PM`s that I am reading right now since I have not been on the page for a while
-Dave
Old 12-11-2003, 05:31 PM
  #7851
Herminator's Avatar
-Dave
mail "system" hmm......
sheesh thats a lot of PM's, now it's 201
Old 12-11-2003, 06:02 PM
  #7852
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
I know, I'm just sayin he's right around the corner from Speedtech, seems to want that imput gear pretty badly, so it's not hard to get.
Randy Caster is offline
Old 12-11-2003, 08:32 PM
  #7853
Default Final drive Ratio for the R2
How do I go about calculating the final drive ratio for my cuda.
Its been suggested to run 6 - 6.50 final drive with rubber tires stock
Jim C
JIMC is offline
Old 12-11-2003, 08:48 PM
  #7854
Paul_Kultcha's Avatar
How many people here run 48pitch on their Cuda's and how many run 64pitch?
Do you run 48pitch on asphault and 64 on carpet?
Paul_Kultcha is offline
Old 12-11-2003, 08:55 PM
  #7855
rc-zombies's Avatar
Stay with the 48 if you don't have the Xenon or PAL drivetrains...
without it....64 gears strips easily.
I've got the PAL on my WEB and run 64p gears. runs smoother, quieter and more finer gear ratios to choose from.
rc-zombies is offline
  #7856
Default Re: Final drive Ratio for the R2
Jim C
I believe the internal ratio is 2.375 on the R2.
Old 12-11-2003, 08:56 PM
  #7857
I ran 64 pitch on asphault with no problems, but I was running the PAL drivetrain. Stick with 48 pitch if you dont have the PAL system.
Old 12-11-2003, 08:58 PM
  #7858
I assume 64pitch on the R3 will be fine due to the new motor mount/shaft holder which is like the PAL system?
Old 12-11-2003, 09:00 PM
  #7859
rc-zombies's Avatar
yes...
Old 12-11-2003, 09:03 PM
  #7860
Herminator's Avatar
2.4375 is the internal ratio
yes 64dp should be ok on the R3, especially if you buy alloy shaft holders too
On the subject of 64dp gears, what size spur do most of you use? Still in half a mind to swap over from 48dp and would like to work out how many pinions I'll have to buy to cover the same range I have now.
