Old 11-18-2003, 11:17 AM   #7276
Maj. Teeth's Avatar
Originally posted by rc-zombies
linger & HEYALIGNMENTGUY
Hope to join you guys out at Stockton soon...
linger...
are you running the short span arms out at Stockton..?
I hear they perform better on carpet. What set-up are you using? I'll probably run stock and 19T.
When is the Stockton Carpet Race?
Dan
Maj. Teeth is offline   Reply With Quote
Old 11-18-2003, 11:21 AM   #7277
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by Herminator
Ok guys, a cuda related question, half suspect the answer but things are slow in here
For those with Speedway PAL type drive shafts, so it can be ina Xenon/pal converted car too, do you only ever use one rubber o-ring at each end, no matter how much movement the drive shaft has?
When rebuilding over the weekend I noticed it could move quite a lot and I could actually fit another o-ring in there, so I tried it with one more. I don't think this was a good idea as the drive shaft now doesn't have any room to move at all and the car was as noisey as it was with the old drive system.
You want maybe .5mm play fore and aft on the shaft. I've cut O-Rings in half in the past to get the right movement...
Old 11-18-2003, 11:21 AM   #7278
Dan
I believe the ROAR regionals are the 14'th or the 16'th (just not 100% sure) I still wanna go if you want to!
Old 11-18-2003, 11:33 AM   #7279
rc-zombies's Avatar
ROAR Region 12 Carpet Championship is on Dec. 5th & 6th.
Practice day all day on the 5th. 3 qualifiers and single A-mains on the 6th.
http://www.stocktonrcraceway.com/
Old 11-18-2003, 11:36 AM   #7280
Nice lookin track... Are rubber tires run in stock, and foams in mod? Or can you run foams in any class?
BTW, do you still wanna sell the SD stuff?
Old 11-18-2003, 11:38 AM   #7281
rc-zombies's Avatar
Rubber tires for stock and 19T.. foam for mod.
SD.. stuff on the way to you...mailed out yesterday
Here are last years results:
http://www.rcracing.com/RaceResultsD...ts.txt&ID=1076
Old 11-18-2003, 11:54 AM   #7282
Cool, I do want to run the race, but having to buy all of those foam tires, and a tire truer is discouraging me... Do you know anyone with a truer I could use?
What do I owe you for the SD stuff, I'll PayPal you ASAP.
Old 11-18-2003, 12:03 PM   #7283
rc-zombies's Avatar
I've got a cobra trackside tire truer you can use....
and there's a good chance other racers will have them at the track as well.....
TQ orange is the only traction compound that can be used.
and 5mm ride height... track is very strict concerning these 2 rules.
SD I'll PM you later..
Old 11-18-2003, 12:15 PM   #7284
Where can I find TQ orange tire sauce?
PM me whenever
Old 11-18-2003, 12:19 PM   #7285
rc-zombies's Avatar
PM me whenever
They always have some at the track to sell...
If you and dan are definately coming up... I'll make sure I have a can waiting for you guys... just in case the track sells out.
Bring lots of spare parts... LHS is far away.
also TQ can be ordered from Speedworld...in Roseville.about 1hr from Stockton.
http://www.speedworldraceway.com/Page.cfm
Old 11-18-2003, 02:19 PM   #7286
linger's Avatar
linger...
Yes, I'm running the short arms. My mod foam tire setup so far:
Front:
Short arms, short camber links. No diff cases, no spacers under inner camber link.
Associated purple springs, 50 wt oil with HPI #2 piston, inner hole on arm. 1.2 sway bar
.5 mm shim under rear arm mount for anti-dive.
Plaid foam tires
Rear:
Short arms, short camber links. No diff cases.
Associated Copper springs, 40 wt oil with HPI #2 piston, outermost hole on arm. 1.4 sway bar
Purple foam tires.
Xenon bottom chassis
linger is offline   Reply With Quote
Old 11-18-2003, 02:37 PM   #7287
Well it'll either be the toys for tots race, or the ROAR regionals for me, can't do both though
Dan didn't seem too interested in going to the ROAR regionals, so I'm not sure that I'll make it up there (as much as I want to do some carpet racing)
Old 11-18-2003, 04:00 PM   #7288
rc-zombies's Avatar
It's understandable...can't be at two places at once.
I'd probably do the Toys for Tots race as well if there was one up here. I'm sure Dan will be doing his part for Toys for Tots..
It's the Holidays..gotta do what we can for the kids.
As Spock would say:
" the needs of the many outweigh the needs of the one "
Old 11-18-2003, 04:06 PM   #7289
The delima I'm having making the decision is, carpet is sooo much fun to race on
lol, how did you fit in a quote from spock?!
Old 11-19-2003, 02:47 AM   #7290
cHckbOY5's Avatar
Send a message via AIM to cHckbOY5
wheres dave?
cHckbOY5 is offline   Reply With Quote
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
