Alex Racing Barracuda R2 & R3
#7051
Originally posted by Randman
The only problem with 64p is that if you dont run a PAL drivetrain, you wont have any teeth on that gear. I would help with a gear ratio, but I've never run a 100 tooth spur, not 57mm foams...
#7052
I run a 96 tooth spur and that nearly sticks through the underside of the chassis so the 100 tooth must be cutting it mighty close
#7053
Originally posted by Gazza_D
Nice....wish I could be mistaken for living in J Land
Herm.....whats wrong with 64dp, its quieter and smoooth as my friend, also gives a few more options with the old ratios
May start changing spur sizes one tooth at a time, should give me enough choice in gearing, just a little slower...
#7055
Originally posted by rc-zombies
I agree..I ran the mine with 64p w/o the PAL drivetrain.. only took 3 mins for the spur gear to be chewed up. After installing the PAL system...the car was more quieter and smoother using 64p gears.
even with 48dp gears I was noticing slight chewing on the normal drive train no matter how well I built it, although the last couple months it's been almost unnoticeable. Now with the Xenon drive train it's a huge amount quieter
#7056
Hear that Joseph, you're a J-Land guy now!
cool bro me some where else now
#7057
Gonna need bigger pinions than that for racing outdoors at the tracks over here. I was running a 47 in stock national at Snetterton this year on a 92 spur (64 dp)
yep thats 4.771 on a brm stock. Thats 41.48mm/rev for those purists!!!!!
#7058
#7061
Originally posted by R/C Anonymous
lol i got a 104 tooth 64 pitch on my cuda right now...havent had any problems with it...u just have to sand the lower chassis down a little where the gear sticks through
#7062
Can someone give me an idea of how many 64dp pinions you can get in a range of two or three 48dp pinions?
Just wondering if I got rid of my pinions 19-34 how many would I need to cover all of the same range but with more choices of course. And yes I do use practicly all my pinions
#7064
can someone help me with gearing?
I'm running a 8t single reedy KR. I'm also running a 100t spur with 57mm tires,what pinion should i use? it's for cleveland
Steve
Steve
#7065
Some nice..........
Dan
Dan
