Old 04-17-2003, 09:55 PM   #691
Regional Moderator
ImGoinRCn's Avatar
Send a message via Yahoo to ImGoinRCn
Are those new camping hubs for the wheels 6mm for foam tires? RB, I raced my cuda R2 on carpet with foams...I love it. Needs to be fine tuned.
tootallracing
When all else fails, aim for the quarter panel.
Several oval and off road vehicles
and a legend car nicknamed Kidney Stone.
X Factory R/C SCX-60CF
X Factory R/C X-6
ImGoinRCn is offline   Reply With Quote
Old 04-17-2003, 10:56 PM   #692
linger's Avatar
yes, the yokomo bladder type shock caps work really well. I already have them installed on mine.
Also, does anyone know if Pro3 castor blocks fit the Cuda?
linger is offline   Reply With Quote
Old 04-17-2003, 11:33 PM   #693
minicooper's Avatar
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
Send a message via AIM to minicooper Send a message via Yahoo to minicooper
Linger, you running the 'cuda car now? Will you be running it at Reedy?
minicooper is offline   Reply With Quote
Old 04-18-2003, 08:58 AM   #694
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Haven't tried the front ones...but the Rear ones Fit just fine
-Dave..
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 04-18-2003, 10:39 AM   #695
Default Re: So Cal set-ups....or not!
Originally posted by madjack
Dave,
I have been running the stock spring so far...next test date will include the following springs, 15600 in front & 15525 in the rear...and back to the mid span arms.
Front
Shock stock piston (drilled with a number #56 bit) 40wt
Spring - kit
Ride height - 5mm
rollcenter - kit
long arms
1.4 sway bar
one way
Xenon alloy hubs - 1 upper link spacer
-.5 toe out
long upper links
Rear
Shock stock piston (drilled with a number #56 bit) 30wt
Spring - kit
Ride height - 5mm
rollcenter - kit
long arms
1.0 sway bar
Xenon 1.0 rear hubs - 1 upper link spacer
-2.0 rear toe
adjust. pivot ball
long upper links
BTW - this was not a set-up I would recomend for a tight track!
JC
Sound's like a good set up..
But why wouldn't you use it on a tight lay out..??
-Dave
Old 04-18-2003, 10:50 AM   #696
tootallracing
Heath have you tried the 6mm HPI Alloy hex's that are used on the Pro# for up front with the Foam tires yet???
-Dave
Old 04-18-2003, 10:57 AM   #697
Wink Alex Racing Batterys
Hey Guys.... Alex Racing Now has there line of GP 3300 Batterys that they are Selling.... ...I'll be trying a set out when I get back.. I'm sure that they are pretty god but the price on a mached set is Way too much to be bothered with 14000 Yen for a 6 cell
Just some infor I thought that I would pass on to you all
-Dave
Old 04-18-2003, 06:47 PM   #698
SpeedTech's Avatar
Hi Guys,
We have a new look for Alex Racing USA's website, check it out when you guys get a chance
www.alexracingusa.com
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 04-18-2003, 07:45 PM   #699
Originally posted by SpeedTech
Hi Guys,
Steve Wang
Why did you change the Look.??
-Dave
Old 04-18-2003, 08:43 PM   #700
Regional Moderator
ImGoinRCn's Avatar
-Dave
Hpi says I can only get them through them and last time I checked, they were sold out. That is why I asked if the alex racing ones were the 6mm.
X Factory R/C X-6
Old 04-19-2003, 09:33 AM   #701
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Default Re: Re: So Cal set-ups....or not!
-Dave
Dave,
It felt lazy...wandered around a bit...kinda like a woman I dated briefly.
I will most likely try it with a higher roll-cernter & stiffer springs next, we shall see if that makes it a bit more planted.
madjack is offline   Reply With Quote
Old 04-19-2003, 10:26 AM   #702
rc-zombies's Avatar
I saw the R2 for the first time at Speedworld...I must say I was very impressed with it's speed, accelereation, handling, and quality of construction.
Old 04-19-2003, 01:16 PM   #703
So do you want one to go with the SD that your gettting..???
-Dave
Old 04-19-2003, 01:24 PM   #704
Hey Heath'
I think that I have a fe extra ones that I might be able to get for you... maybe even in Blue too
-Dave
Old 04-19-2003, 01:29 PM   #705
Default Re: Re: Re: So Cal set-ups....or not!
Dave,
I know for a fact that you'll like the Higher rear roll center....but you might want to up the rear sway bar to a 1.2mm when you do raise it ..
-Dave
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
