Alex Racing Barracuda R2 & R3 >
Old 11-12-2003, 02:20 PM
  #7006
Gazza_D's Avatar
So the 9550 servo, is it an analogue or digital servo and does it have metal or plastic gears????? Excuse the ignorance, only have Sanwa and KO servos
Gazza_D is offline
Old 11-12-2003, 02:24 PM
  #7007
rc-zombies's Avatar
Default FUTABA S9550 SPECS
Here are the specs:
FEATURES:
Digitally Enhanced Microprocessor Cut About 1/2 of the Response
Time From Transmitter Input To Servo Reaction.
Low Profile allows for the servo to fit into wings and lay
down in car chassis for less obstruction.
Coreless Motor
Metal Gears
Dual Ball-Bearings
High Torque
Case is Made of Black Plastic
Dust and Water Resistant (Not Waterproof)
High current/Low resistance servo leads.
Ideal for F3A aileron application and 1/10 scale electric
touring car
SPECS:
Speed: .14 Sec/60 Deg @ 4.8V or .11 sec/60 deg @ 6V
Torque: 67 oz/in @ 4.8V - 83 oz/in @ 6V
(4.8 kg/cm @ 4.8V - 6.0 kg/cm @ 6V)
Weight: 1.6 oz (45g)
Length: 1.6" (41mm)
Width: 0.8" (20mm)
Height: 1.0" (25mm)
rc-zombies is offline
  #7008
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
It is a digital servo. Not sure if it has metal gears or not. I would think that it does but I would check the Futaba website and see if it tells you.
wyd is offline
Old 11-12-2003, 02:32 PM
  #7009
Gazza_D's Avatar
Cheers for the info guys
not that I need to create anymore space:-
(a little out of focus but you get the idea!)
Gazza_D is offline
Old 11-12-2003, 03:04 PM
  #7010
Herminator's Avatar
Well you could put the reciever on the chassis, I can just about do it with my KO servo, KO reciever and MRT VX Pro speedo, but using velcro to attach them at the moment means they move a little and the speedo can touch the endbell of the motor if I have them like this. It would actually touch the end of the armature so I don't want that. I have the reciever ontop of the servo for now but the Cirrus should be here in two days and I should be able to fit it along side the reciever on the chassis and have a bit more clearence. If I had a 9550 there would be bags of room
Herminator is offline
Old 11-12-2003, 06:18 PM
  #7011
Paul_Kultcha's Avatar
thx guys, the Futaba 9550 servo seems to be the way to go.
Paul_Kultcha is offline
Old 11-12-2003, 11:07 PM
  #7012
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Why are you usin velcro to hold your stuff in place herm?
Randy Caster is offline
Old 11-13-2003, 10:24 AM
  #7013
And once again, where the heck is everyone???
The other night I had over 3 pages to catch up on, and last night, no posts at all
Old 11-13-2003, 10:31 AM
  #7014
berger's Avatar
Im here the new barracuda anodised colour is brown though.
berger is offline
Old 11-13-2003, 10:32 AM
  #7015
Regional Moderator
ImGoinRCn's Avatar
ewww
ImGoinRCn is offline
Old 11-13-2003, 10:35 AM
  #7016
lol, that would definately suck.
Old 11-13-2003, 10:39 AM
  #7017
Herminator's Avatar
Well Back when I got my Cuda I also had the RC Lab to swap electronics into so velcro was the quick and easy choice. Now I've got the new chassis and new speedo (tomorrow hopefully) I will probably try and find some nice strong double sided tape. The velcro I've been using is strong stuff though, made for heavy duty applications, like holding sub boxes in the boots (trunks for you overseas people) of cars.
  #7018
rc-zombies's Avatar
brown..
Old 11-13-2003, 11:04 AM
  #7019
I've always used servo tape, gotta have that low CG man
If you can find it over there, MIP tape is "da bomb" it holds strong, but when you go to take the electronics out, it doesnt rip and tear.
Old 11-13-2003, 11:05 AM
  #7020
Thinking about getting back into TC. I want the Cuda but I don't konw if I should wait for teh R3 or not.
Adam Hartzell is offline
