Alex Racing Barracuda R2 & R3 >
Old 11-09-2003, 11:01 PM
  #6736
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Originally posted by JDM_DOHC_SiR
Making parts now are we ..
I have a santas list of parts that need to be made
-Dave
Before long
Randy Caster is offline
Old 11-09-2003, 11:05 PM
  #6737
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by Randman
Before long
Good news
JDM_DOHC_SiR is offline
Old 11-09-2003, 11:18 PM
  #6738
Good news
You're tellin me I cant wait, I'll definately have to ask you for some help on ideas of what to make though...
Old 11-09-2003, 11:20 PM
  #6739
I sure will give you a bunch of ideas what maker of car hahaah Yokomo/ALEX/HPI ect ect
here's a hint get a chassis ready for the Pro4
-Dave
Old 11-10-2003, 01:40 AM
  #6740
cHckbOY5's Avatar
dave ygpm
cHckbOY5 is offline
Old 11-10-2003, 01:49 AM
  #6741
Originally posted by cHckbOY5
dave ygpm
Back to ya"
Old 11-10-2003, 02:53 AM
  #6742
Herminator's Avatar
Try taking the dang spacers out of the shocks and they will work just fine I can get all the way down to a 4mm ride height with the Rayspeed Springs
-Dave
Spacers in my shocks Don't have any on there.
Herminator is offline
Old 11-10-2003, 02:59 AM
  #6743
OK then what kind of ride height are you getting with the RS springs..???
I know for a fact that you can get to 4mm
-Dave
Old 11-10-2003, 03:00 AM
  #6744
cHckbOY5's Avatar
dave wats ur trick in gettin the bevel input gear in the bearing n shaft?
cHckbOY5 is offline
Old 11-10-2003, 03:04 AM
  #6745
Herminator's Avatar
-Dave
Well the front was ok at around 6mm but the rear was rally car style with about 1cm
The shock positions were the center holes on the shock towers front and rear and on the suspension arms the front were on the outer holes and the rear one in from the outermost holes.
They tyres won't be helping, mini pin tyres have quite a large profile, but they were bald and should only add 1mm or so on the average slick tyre height.
Old 11-10-2003, 03:05 AM
  #6746
Put one bearing on the Bevel gear half way then put the other bearing onto the other side of the Alloy shaft holder and once you can see the tabs of the bearing making contact with the bearing put a little oil or WD-40 on the Bevel gear tabs then.................. get readdy to push down on the bevel gear( use a hard flat surface to do this) and then with a little effort it will pop right down over the other bearing
but I think that a Picture would better to discribe this
-Dave
Old 11-10-2003, 03:08 AM
  #6747
Now that makes a differance... you didn"t say that you wre using the 4x4 super offroader mini pins that might be the differeance.. well what stiffness springs are use using .. mabe I can find the Alex spring that you need...
-Dave
Old 11-10-2003, 03:14 AM
  #6748
Herminator's Avatar
Well I was going to try yellows and blues, gone back to what I was using last week in Alex Racing springs but one harder up front.
So it's 6.75x1.4 at the rear and 6.50x1.4 at the front.
Old 11-10-2003, 03:16 AM
  #6749
Herminator's Avatar
-Dave
PS. expect pic to arrive in upto 28days.
(still havent seen your nice new shell )
Old 11-10-2003, 03:20 AM
  #6750
WHich new one...man I have soooooooooooooooo many that I have been painting it"s mind warping 5 1/12 scale bodies in the past week and 3 TC bodies on th past month ...speaking of which..one is yours ..
But I think that you are talking about the Orange Body...
that Body is waiting to be show.
-Dave
