Alex Racing Barracuda R2 & R3 >
Old 11-08-2003, 04:45 PM
  #6676
Herminator's Avatar
Originally posted by cHckbOY5
i sanded the chassis but i could still see graphite lines... how much am i suppose to sand?
you're always going to see lines, the graphite is woven so there are layers running all the way through it You just need to sand it to take the sharpness off the corners. Some people say go as far as to creat a totaly rounded edge, you'll be forever if you try that though, I just try and get a nicely smooth corner, still with a defined flat edge.
Herminator is offline
Old 11-08-2003, 04:49 PM
  #6677
Herminator's Avatar
Originally posted by Randman
I'd think you'd want a balanced car from front to rear on a low traction surface. I usually try to keep the same spring rates on my cars, just makes them more predictible in my mind...
I try to keep sring rates close front to rear, normaly within one grade but often found one rate stiffer up front helps balance the car for me.
On the same theme, whats this "magic" combination of Rayspeed springs Dave keeps saying he likes and I think KO too, reds and whites I think but which way round.
Old 11-08-2003, 04:50 PM
  #6678
Herminator's Avatar
Originally posted by JIMC
I notice the R2 does not come with the set screws used to set the droop.
What size would they be and who might I get them from
There were screws in my kit that I used for set screws, they are the same as those used to attach the top deck.
Old 11-08-2003, 04:56 PM
  #6679
Bartz!'s Avatar
Arrow R2 Spring Ratings...
Does anyboday have a chart that will give spring contant values for the R2 springs available on Speedtech. I'm used to the numbers on Associated/Yokomo style springs and they are expressed in pounds. I want to get some R2 springs but want to know how their numbers will compare to what I already have.
Thanks For the Help!
Bartz! is offline
Old 11-08-2003, 05:50 PM
  #6680
madjack's Avatar
Trader Rating: 25 (100%+)
Wink Pal hollow graphite drive shaft.
to all....or Dave,
What type of motor limit can you throw at the Pal hollow graphite drive shaft
I have run it with stock no problem, but was considering a 19T motor.
your thoughts?
thanks,
JC
madjack is offline
Old 11-08-2003, 08:51 PM
  #6681
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
Bartz check out page 206 of this thread as they have the springs listed their for the R2
wyd is offline
Old 11-08-2003, 10:40 PM
  #6682
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Pal hollow graphite drive shaft.
Originally posted by madjack
to all....or Dave,
your thoughts?
thanks,
JC
[email protected] have gone as low as a KR 7 Double... but I would not recommend it at all... I would say anything under a 17 turn is pushing your luck...I have distroied 3 of them..I only run the Alloy shft now..*
[email protected]
JDM_DOHC_SiR is offline
Old 11-08-2003, 10:59 PM
  #6683
Paul_Kultcha's Avatar
How well do the Delrin Diff Halfs hold out? I've only run off road before and I can't imagine using delrin diff halfs despite the weight savings.
(sry if this has been asked before)
Also, how many people run the lexan gear covers?
thx
Paul_Kultcha is offline
Old 11-09-2003, 01:11 AM
  #6684
John_S's Avatar
while iv been racing the car it hink the outdrives are exelent and hold up as well as any other outdrive may be and i think most people only run the gear covers if there on a track with lotsa little stones or debris that can chew up the gears so if your track is fairly clean u will be ok running without them
John_S is offline
Old 11-09-2003, 01:39 AM
  #6685
Herminator's Avatar
thx
Delrin diffs are fine for touring, they're fairly solid and I plenty strong enough for most crashes. You get very little wear on the outdrives, thanks to Delrins self lubrication.
Old 11-09-2003, 01:40 AM
  #6686
cHckbOY5's Avatar
aite im on the step where i have to put the gear in the shaft holders... man its tough! i struggled to get one in... the for the second gear... it snapped! now i gotta go order another one ... ahh n speedtech is out of stock
cHckbOY5 is offline
Old 11-09-2003, 01:54 AM
  #6687
Herminator's Avatar
It gets easier when you learn the technique
I make things easier by taking a sharp scalpel and taking a VERY small amount off the corner of the two tabs so it's angled to help stop it catching on the bearing when going in but has all the normal surface stopping it from coming out of the bearing. A little shock oil can help it slide in easier too.
I then squeeze it with pliers and put one side of the join in first, so it's at an angle when I'm pushing it in but both tabs are in contact with the bearing. Once the tabs are inside the bearing a good hit with something heavy will have it in place. Then comes the second bearing which is tricky since there's no plier room because you're putting it in the shaft holder. I line up the gear as before, trying to ge the two tabs to start squeezing in and place the gear on a table and then hit the shaft holder with something heavy, a hammer if you've got one. If it's lined up right then it goes in reasonably easily.
Old 11-09-2003, 02:00 AM
  #6688
cHckbOY5's Avatar
what about for the shaft ends, wat is the small thing that goes in the holes? some sort of screw? wat do i use to screw it?
cHckbOY5 is offline
Old 11-09-2003, 02:26 AM
  #6689
Herminator's Avatar
You should have two small grub screws, the same things that are used in pinions. Make sure you put some super glue on the flat section of the carbon shaft before you assemble it though and let the glue dry so there is a hard sruface for the grub screw to tighten onto.
Old 11-09-2003, 06:10 AM
  #6690
Regional Moderator
ImGoinRCn's Avatar
okay, chck, get some diagonal wire cutters,(dikes), because it has a narrow cutting area, you can use it to squeeze it enough to slip it past the bearings. I have replaced one pinion gear and then installed aluminum shaft holders. I didn't have any trouble, you just have to be careful. I never used shock oil or anything like herm, but it could help. Once you get one of them, the other will be easy...hope this helps. I know this picture isn't the one I wanted but here it is. They are the 7 inch model, not those real small ones.
ImGoinRCn is offline
