Alex Racing Barracuda R2 & R3 >
Like Tree4Likes
Old 11-05-2003, 06:05 AM
  #6511
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by Tsubasa Sakai
Dave: Can you get any PM from me?I need your reply as soon as possible.
Back to ya
JDM_DOHC_SiR is offline
Old 11-05-2003, 10:33 AM
  #6512
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
YGPM from me too Dave
Randy Caster is offline
Old 11-05-2003, 12:12 PM
  #6513
Herminator's Avatar
Dave- YNotGPM from me
although it would be nice to know what those Japanese postal guys are smoking
Herminator is offline
Old 11-05-2003, 12:14 PM
  #6514
Regional Moderator
ImGoinRCn's Avatar
I bet it ain't rubber on their delivery trucks...
ImGoinRCn is offline
Old 11-05-2003, 12:50 PM
  #6515
sands's Avatar
Looking for a stock carpet setup. Tight twisty track. Any suggestions?
sands is offline
Old 11-05-2003, 12:55 PM
  #6516
I believe one was posted a page or 2 back.
Old 11-05-2003, 01:02 PM
  #6517
Regional Moderator
ImGoinRCn's Avatar
Default Re: Carpet Setup
Originally posted by ImGoinRCn
Let's see if this works...I couldn't do it in a .pdf file, not too familiar with A.A. It's close to EA's but a little different.
try this...it's really close
Attached Thumbnails Alex Racing Barracuda R2 & R3-11-1-03-heathcudasetup-carpet.jpg
Old 11-05-2003, 01:04 PM
  #6518
Regional Moderator
ImGoinRCn's Avatar
Default Re: Re: carpet set up
Originally posted by EAMotorsports
Here is my setup from this weekend...It was ballistic in 19 turn with foams.
50wt oil with #2 pistons front and rear.
Rayspeed red front springs and white rear springs
Front shocks outer hole in tower and outer hole in arm
Rear shocks 3rd hole in on tower and all the way out on arm
no kick up or anit squat
5 degrees front castor
3 degrees rear toe
2 degrees camber front and rear
plaid front tires and purple rears
Speedway pal upper deck mounts with front one in raised positon and rear in lower positon.
Xenon chassis kit
5mm ride height front and rear
1.5 mm drop front and 2 mm rear using ride height guage to measure uptravel from ride height.
I thnk thats about it.
ea
Same track, same car...
Old 11-05-2003, 03:56 PM
  #6519
Gazza_D's Avatar
Gee, sure is quiet in here today have all you guys gone on vacation or something
Need my regular Cuda info fix, with pictures too....Dave???
Gazza_D is offline
Old 11-05-2003, 04:02 PM
  #6520
It definately has been a quiet day... Good thing I'm back in the SD thread, it's moving...
Old 11-05-2003, 04:03 PM
  #6521
Gazza_D's Avatar
Is that why you change cars regularly???? J/K
Gazza_D is offline
Old 11-05-2003, 04:05 PM
  #6522
It's definately one of the perks of changing cars... Every track I go to, someone new will know me. Pretty crazy.
Old 11-05-2003, 04:16 PM
  #6523
Gazza_D's Avatar
When you gonna build and run that Web. I think mine is awesome, and soon to get better too, Pal spec A Web mmmmmm
Gazza_D is offline
Old 11-05-2003, 04:30 PM
  #6524
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
This thread is normally pretty happening. Hard to keep up with what is going on.
Since my tire machine was stolen at our track while I was racing I decided to run some gas off road. I will wait for awile and see if I can track down the guy that I think took it.
I think I will just hold out to see what the new Cuda is like. I think when I go touring racing again it will be with an R3 or a XXX-S G plus. I do like the way the Cuda arms are mounted. It is a very interesting system to me.
wyd is offline
Old 11-05-2003, 06:55 PM
  #6525
so did you get it yet..??
-Dave
