Alex Racing Barracuda R2 & R3 >
Old 11-04-2003, 02:55 PM
  #6496
Regional Moderator
Originally posted by cHckbOY5
r the screws for the front one-way included in the ti screw set?
Are you talking about the screws to hold the gear it self on?
If so know there not and it it wouldnt make much difference anyways.
Ko Racer is offline
Old 11-04-2003, 04:58 PM
  #6497
Default Does the R2 come with sway bars??
If the R2 comes with sway bars what size???
If not which size should I start with , 1.4's maybe???
rubber tires on carpet, i'll be running on
or do I need to bother with sways yet.
Jim Crider
JIMC is offline
Old 11-04-2003, 05:40 PM
  #6498
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Does the R2 come with sway bars??
Jim Crider
I would start of with a 1.4 set and a 1.2
-Dave
JDM_DOHC_SiR is offline
Old 11-04-2003, 05:50 PM
  #6499
Default Thanks Dave!
How are the sway bars packaged.
If I order 1.4's do I get one 1.4 and hardware or do I get a pair of 1.4's and hardware.
What pitch and size is the spur in the R2 kit
I'm thinking about getting the Robinson machined spur
Is it 72 tooth and 48 pitch???
Jim C
JIMC is offline
Old 11-04-2003, 05:58 PM
  #6500
Regional Moderator
Default Re: Thanks Dave!
Jim C
you get 1 and yes its 72 /48 pitch
Ko Racer is offline
Old 11-04-2003, 06:01 PM
  #6501
Jim C
they only come one per kit when you buy the R2 ones
and the stock kit spur is 72T
-Dvae
Old 11-04-2003, 06:02 PM
  #6502
thanks KO RACER
MY R2 should be here thursday.....man, i should have went with 2nd day.
Thanks Dvae!!!!
JIMC is offline
Old 11-04-2003, 07:47 PM
  #6503
Regional Moderator
ImGoinRCn's Avatar
KO, did you get a hold of Steve yet about your parts and the sway bar question we had? Also, I sent you a PM earlier...
ImGoinRCn is offline
Old 11-04-2003, 08:21 PM
  #6504
Regional Moderator
heath you have a message
Ko Racer is offline
Old 11-04-2003, 08:23 PM
  #6505
Regional Moderator
ImGoinRCn's Avatar
okies
Old 11-04-2003, 08:40 PM
  #6506
rcsabah's Avatar
it's included in the Ti screw set. lighter drive train are better
rcsabah is offline
Old 11-04-2003, 08:57 PM
  #6507
Dave: Can you get any PM from me?I need your reply as soon as possible.
Tsubasa Sakai is offline
Old 11-05-2003, 12:18 AM
  #6508
cHckbOY5's Avatar
do i need to use thread lock for the diff?
cHckbOY5 is offline
Old 11-05-2003, 12:39 AM
  #6509
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Are we letting the other thread die out?
Just one more thing to keep track of, easier to just use 1 thread.
Randy Caster is offline
Old 11-05-2003, 12:41 AM
  #6510
I never have...
