Alex Racing Barracuda R2 & R3 >
Old 11-03-2003, 08:03 AM
  #6436
Herminator's Avatar
You guys not heard of email?
You trying to get some other way of buying sway bars? instead of having to pay for several mounting bits when you only need one set and a few different bars. Seems silly the way they are sold at the moment
Looks like with the R3 you're going to need small electronics just to be able to fit the weights on
I wish they'd change the cut outs on the servo/motor side, the cell shaped ones are a pain when you're trying to mount an ESC securely. I don't think anyone really uses the cut outs for cells, so why not make them triangular or something so there is some more support, even just add an extra bit in the middle of the cell shaped cut outs going from the front of the chassis to the back, so it's like four squares and you can cut out the extra bits if you're weird enough to want two cells there.
Herminator is offline
Old 11-03-2003, 08:08 AM
  #6437
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Thats why if you buy the R1 sway bar kits they come with only the sway bars 2 of them per kit.. example 1.0 and 1.2 /1.4 & 1.6 ect ect... all you would have to do is get a bit creative with a dremel and a cutting bit to make them fit the 5mm spacers
-Dave
JDM_DOHC_SiR is offline
Old 11-03-2003, 08:12 AM
  #6438
Herminator's Avatar
Hehe, sometimes a gentle nudge is needed
I find the problem with the Cuda is it's acceleration, I can be following someone closely but cleanly, then out of a corner I simply accelerate and find I've gently pushed the rear end of the slower accelerating car infront
Don't do it often, honest
  #6439
Regional Moderator
ImGoinRCn's Avatar
Default Carpet Setup
Let's see if this works...I couldn't do it in a .pdf file, not too familiar with A.A. It's close to EA's but a little different.
Attached Thumbnails Alex Racing Barracuda R2 & R3-11-1-03-heathcudasetup-carpet.jpg
ImGoinRCn is offline
Old 11-03-2003, 08:16 AM
  #6440
Sounds like you have my problem... you get out of the corners way fater than the other cars
-Dave
Old 11-03-2003, 08:21 AM
  #6441
Gazza_D's Avatar
Had that problem in the stock class, especially when running behind some belt driven cars Nailed the throttle then had to either swerve or get right out of it as I closed on the back of their cars too quick.
Was great when I got used to it though
Gazza_D is offline
Old 11-03-2003, 08:23 AM
  #6442
Herminator's Avatar
-Dave
You eating donuts mid corner?
Must have some serious talent to be able to steer and eat at the same time
Old 11-03-2003, 08:24 AM
  #6443
Regional Moderator
ImGoinRCn's Avatar
he is getting fatter...Navy will do that to ya, I guess...j/k Dave
Old 11-03-2003, 08:52 AM
  #6444
Regional Moderator
Originally posted by ImGoinRCn
As seen on the back of KO's cuda: "If you can read this, you are TOO CLOSE!" I was following him setting up for a pass and I nudged him over a time or ten...lol, I'm sorry, I got his buddy, too...but he drives a TC3 so it didn't matter... JUST KIDDING DENNIS...lol...maybe by the end of the season, my skills will be back.
LOL heath oh yeah a little tap from time to time is a good thing . this season will be great and the driving will be tough as always so when you pull the car off the track and you see speedway pal or a KO decal on your body, baby you know KO has been by and gave you that gentle tap
Ko Racer is offline
Old 11-03-2003, 09:00 AM
  #6445
Regional Moderator
It also helps when you have some killer motors like he does and did you see the batteries that he's running Power baby .....power SMC...................... Oh ya and then theres the cuda in the mix too
-Dave
oh yeah bro I saw those SMC's and motors this man can build a motor heck Im trying to think of something he cant do and I cant seem to think of anything
Im hoping soon to be trying out some new juice so I will go from there and see if I make a change
Ko Racer is offline
Old 11-03-2003, 09:03 AM
  #6446
Regional Moderator
... it's good to see that you guys have a "STRESS" free racing attitude .... that plays a big factor when trying to have fun with the guys
-Dave
Oh its gotta be stress free its just a hobby no need to drag heath outside and beat the @#! out of him
Ko Racer is offline
Old 11-03-2003, 09:11 AM
  #6447
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Man I don't even drive a EVOIII but I know how to make the car stop gearing gears
Can you say 3 piece shaft
-Dave
I can do it without the center shaft So Dan, if you ever do build that car, just let me know
Randy Caster is offline
Old 11-03-2003, 09:14 AM
  #6448
Default Re: R3 ..testing news
Hey guys on the K&K home page Kitoma has been doing more testing with the R3 and ... some of the differences that he has notices is that turn is much better and , cornering speed is up ...(a already fast cornering car is now faster ) just for starters
-Dave
Is that a transponder on the upper deck or???
Old 11-03-2003, 09:17 AM
  #6449
5 out of 5 for me... got it every time I called
-Dave
Dang, I've gotten it once when I called after 6, but never during the day...
Make sure you call when he's open (pacific time)
Old 11-03-2003, 09:21 AM
  #6450
You could always make a PPV event outta it
