Alex Racing Barracuda R2 & R3 >
Old 10-31-2003, 09:47 AM
  #6271
Mercury Racer's Avatar
Hi steve,
just to clarify, did you use straight 40 on your R2? how did you find it, as oppose to the 20wt oil in front and 10wt oil at the rear as suggested in the manual?
also, have you tried the diapharam on the R2? would you recommend it?
Mercury Racer is offline
Old 10-31-2003, 02:43 PM
  #6272
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by racer
are there any other type of shocks that can be used with the R2?
when i squeeze the shocks, it starts leaking on the lower rubber seal. should i bleed the shocks alittle more?
what kind of dampers do most of you use? the stock or modified?
The stock ones work just fine
-Dave
JDM_DOHC_SiR is offline
Old 10-31-2003, 02:46 PM
  #6273
Trader Rating: 26 (100%+)
-Dave
Dave-
Someone must have hijacked Santa because nothing has arrived yet!
MDawson is offline
Old 10-31-2003, 02:48 PM
  #6274
Thumbs up All Japan Sportsman Championship
Hey guys .......today the 3 day Race starts at Yatabe Arena This is where the Barracuda R1 took home the win last year.... ... I will be going today tommorow and Monday to get you all pic's and such .... Hopefully the R2 can pull it home for ALEX Racing again ......
-Dave
Old 10-31-2003, 02:51 PM
  #6275
cHckbOY5's Avatar
will masami n hara be competing in this event?
cHckbOY5 is offline
  #6276
Originally posted by MDawson
Dave-
You have a PM
Old 10-31-2003, 02:54 PM
  #6277
Herminator's Avatar
Dave-
a little early for Santa isn't it?
i know how you feel though....
Herminator is offline
  #6278
nope.. They are in the"EXPERT" class
this is the "SPORTSMAN" class which is more popular than the Expert series .... because these are your every day joe's that can turn better laps with a 23T stock motor some times that the guys with modifieds..at Yatabe..... also this race is where you see a lot of new stuff....
-Dave
Old 10-31-2003, 02:55 PM
  #6279
just count 3 for you too..
I found out about it
Old 10-31-2003, 02:59 PM
  #6280
Herminator's Avatar
-Dave
Surely if they're that fast they should get moved up to the "expert" class
Aren't your mod times kept a little slower though by the fact that you use 8minute runs. Wish the UK had atleast gone up to 6mins this year but no not even a change from 12 to 10 turn mods. Think I'll stick to the 19's again next year, plenty speed and much cheaper motor's Plus I have a chance of some wins
Old 10-31-2003, 03:01 PM
  #6281
Santa is in the Far East this time of year. He actually works 365 days a year. Needs to get a jump on the Bunny, Candy Hearts, Vampires and Goblins.
MDawson is offline
Old 10-31-2003, 03:02 PM
  #6282
racer's Avatar
-Dave
should there be any resistance when i compress the dampers?
how far should the damper rod spring back after being compressed?
maybe i'm assembling them incorrectly.
any help would be appreciated.
Thanks!
racer is offline
Old 10-31-2003, 03:08 PM
  #6283
berger's Avatar
Oh i need to pimp myself to get money for a R3, broke a diff outdrive and a front hub carrier tonight racing my tc3, was absolutly fantastic in the 1st heat, allmost perfect race, few little errors and letting some people through cost me 5 seconds but an almost perfect 29 lapper. Rest of my night was crap. Broke my outdrive and spent the next heat rebuilding my diff. Theres not a lot of time inbetween heats so couldnt fix it in time. Got stuck down in the B with the kiddies as its best of two heats, i had 29 and 18 laps, they had two lots of 24 and bashed to hell in the final. Even when lapping they aim for you i swear. Broke the hub a couple of laps from the end and limped round on two wheels using my couple of laps cushion i had to take the win.
Need an R3 that i can rely on to be as fast as my tc3 but more robust. Anyone got more photos of it or a link to em?
berger is offline
  #6284
Herminator's Avatar
hmm, cryptic clues, I'll work it out in the morning, head hurts after whacking it off a door this morning and then taking well over 5 hours to do a 3 hour drive and for the last two hours I couldn't find one decent radio station, it was one dance music rubbish and the rest old fogey's music
Old 10-31-2003, 03:12 PM
  #6285
Thanks!
there should be Slim to none for resistance
as far as the rebound of the damper pistion.. I ususally set mine to about 2~3mm
-Dave
