Alex Racing Barracuda R2 & R3 >
Like Tree4Likes
Old 10-21-2003, 07:13 PM
  #5656
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by ImGoinRCn
Dave,(JDM), you have a PM
Got it thanks
JDM_DOHC_SiR is offline
Old 10-21-2003, 07:15 PM
  #5657
Regional Moderator
ImGoinRCn's Avatar
Originally posted by JDM_DOHC_SiR
Got it thanks
ImGoinRCn is offline
Old 10-21-2003, 07:16 PM
  #5658
Regional Moderator
ImGoinRCn's Avatar
Originally posted by NismoSkyline17
Can't wait to get my box. Then I can put wheels on it and race it. Poor aerodynamics though.
that avatar is too much lol
Old 10-21-2003, 07:19 PM
  #5659
Herminator's Avatar
Default Re: Re: Ceramic bearings
Hmm Ceramics ...how much are they...they have to be cheaper that 180+ a set
-Dave
180 a set
You'd have to be nuts to buy them at that price
So how many sets have you bought Dave?
EAM- if they're cheap I'm sure lots of us would be interested really cheap and you may even interest me
Herminator is offline
Old 10-21-2003, 07:30 PM
  #5660
Regional Moderator
ImGoinRCn's Avatar
Default Re: Ceramic bearings
Originally posted by EAMotorsports
Any of you guys interested in some ceramic bearings for the cuda.
Hey Heath...You going to fernando's for the tristate race this weekend? Im taking the cuda down to see how good it is on rubber tires....It was DIALED on foams this past weekend at the Alabama race.
eric
I can't go to Fergie's this weekend, got to work in the morning and besides, too much going on here at home with some issues here...
Old 10-21-2003, 07:33 PM
  #5661
eric
The Cuda's drive train is so free, why would you need them?
NismoSkyline17 is offline
Old 10-21-2003, 07:45 PM
  #5662
Speedtech im running on medium trction to high traction carpet...basically a Trackside of Milwaukee setup would do perfectly...plaid and purple TRC's, Stratus 2.0 body... about 110 foot straightaway or so i believe and lots of turns of course...good start im guessing
R/C Anonymous is offline
Old 10-21-2003, 07:47 PM
  #5663
fowlerJr68's Avatar
hey, whats the difference between the R1 and R2? Like i know the shocks are infront of the shocktower instead of infront but what does that do to the handling?
STeve
fowlerJr68 is offline
Old 10-21-2003, 07:48 PM
  #5664
Brings more of the weight to the middle of the car.
Old 10-21-2003, 08:11 PM
  #5665
Team EAM
Trader Rating: 79 (100%+)
If you had ever felt a shaft drive with ceramics youd know why youd want them...They will double your spin time just by installing them...no BS.
If I can get enough orders I can sell them for 90-100 range. But need to see if the interest is there before I chunk the change over
ea.
EAMotorsports is offline
Old 10-21-2003, 09:16 PM
  #5666
SpeedTech's Avatar
How does the car feel to you right now? Are there any handling characteristics that you dislike that you would want to tune out? Sounds like a pretty good size track so about 1 second off the pace isn't all that bad. Might just need some fine tuning
Steve Wang
SpeedTech is offline
Old 10-21-2003, 09:18 PM
  #5667
Regional Moderator
ImGoinRCn's Avatar
anyone have any pics on how the sway bars mount?
Old 10-21-2003, 09:26 PM
  #5668
Speedtech...it pushes real bad entering corners...im used to the back end kinda being controlably loose cuz i drive faster that way...im guessing once i get my off centerballs and the different rear hubs and PAL system it should be better im hoping...im loosing it in the corners not on the straightways
Old 10-21-2003, 09:32 PM
  #5669
SpeedTech's Avatar
R/C Anonymous,
It pushes because it has too much rear toe-in making the car too stable in the rear. The A6113 rear hub will reduce it by 1 degree and the off-set center balls can reduce it by another 1 degree. That should help free up the rear end a bit. Another thing you can try after these adjustment is putting a shim (from the A6511 shim kit) underneath the front rear suspension ball mounts (just a 0.5mm can have a pretty dramatic affect) that should make the front dive even harder into the turns. Give those a try
Steve Wang
Old 10-22-2003, 01:29 AM
  #5670
Have a look ....Now much faster to change...and the spacer is now intigrated into the Bulkhead
-Dave
