Old 10-12-2003, 07:57 AM   #5296
Shark's Avatar
Originally posted by SpeedTech
Shark,
I don't think it really matters, as long as you are consistent everytime.
Steve Wang
Steve,
isn't it right that front droop can affect the steering ability of your car? The reason why i'm asking is that I have a set up that I want to try out, but i dont know how to measure properly the front droop of this car.
Thanks in advance!
Shark is offline   Reply With Quote
Old 10-12-2003, 10:23 AM   #5297
Randy Caster's Avatar
Trader Rating: 46 (100%+)
The front droop can effect the steering only coming out of corners, if you need more steering going into the corner, give more rear droop.
Old 10-12-2003, 10:51 AM   #5298
Regional Moderator
R/C Tech Charter Subscriber
Originally posted by Randman
Joseph you have a PEEEEEE MMMMMMMM
You tooo
Ko Racer is offline   Reply With Quote
Old 10-12-2003, 11:13 AM   #5299
lol
Old 10-12-2003, 11:27 AM   #5300
Regional Moderator
lol
How you and that new car getting along ? (the real car)
Old 10-12-2003, 11:35 AM   #5301
Real well, the reason I'm selling some stuff is because it's going into the shop on Tuesday to get some work done
I'm gonna have a custom made FMIC put on there within the month as well, so that'll help condense the air for some more power
Old 10-12-2003, 11:39 AM   #5302
Regional Moderator
Sweet man ! i sure do miss some of those trick shops out in so cal
that is where its starts and then spreads to the east it seems. nice custom rides what color did you get?
Old 10-12-2003, 11:48 AM   #5303
I got white with gold wheels. I was going to go with silver wheels, but since the car has gold brembo brakes, I wanted to match Looks really good IMO
Old 10-12-2003, 04:37 PM   #5304
fowlerJr68's Avatar
whats the difference between the Original Barracuda and the R2?
if there are any differences, would it really affect the overall handling?
thanx
Steve
fowlerJr68 is offline   Reply With Quote
Old 10-12-2003, 05:29 PM   #5305
Shark's Avatar
Droop Settings
Thanks Randman.
With this i wanna go back to what im really asking for: how do you measure front droop in the R2, against the base of the Hub carrier or the screw at the bottom of the Hub carrier (both can give different droop numbers)?
btw, when you mean give more droop, do you mean higher numbers based on droop gauge level (e.g. from 4 to 5) or the reverse?
Sorry if i sound dumb. just wanna make sure im doing the correct settings to my car
Old 10-12-2003, 06:10 PM   #5306
Herminator's Avatar
Send a message via ICQ to Herminator
thanx
Steve
The chassis is slightly different, the alloy shaft holders on the original use one bearing instead of two, slightly different A arms (I think )
The main difference is the chassis, with the cells on the R2 being closer to the center, giving a better balance.
Herminator is offline   Reply With Quote
Old 10-12-2003, 06:16 PM   #5307
fowlerJr68's Avatar
thanx for the info
STeve
Old 10-12-2003, 06:19 PM   #5308
Herminator's Avatar
Default Re: Droop Settings
Originally posted by Shark
Thanks Randman.
The usual place to measure droop is the bottom edge of the hub or end of the suspension arm.
More droop is when the suspension arm can go lower, and should mean a higher number, but I've seen gauges with different numbering systems it's about time I bought my own actually
Old 10-12-2003, 08:46 PM   #5309
Thanks Randman.
More droop actually means a lower #, allowing the suspension to have more downtravel.
Old 10-12-2003, 08:58 PM   #5310
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Thumbs up Real R3
Hey guys the owner of ALEX will be at the Local Ragi Ten(my local trak) today and they will be testing the R3 today!!!!! ....I might get a change to drive it....( if I`m lucky )I`ll let you all know how it goes
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
