Old 09-13-2003, 12:05 PM   #4531
Regional Moderator
R/C Tech Charter Subscriber
Originally posted by ImGoinRCn
what's a cuda? what's a file? does it have papers in it? what's an RC? who are you? Ko, I take it by you being online that you aren't coming..lol I'm not going there either...check, I'm picking on ya brother...
lol heath your crazy man you are heath right
nope i wont be there today just got in off the lake been boating all day . my home boys i dont know whats up with them lol but next race count me in
Ko Racer is offline   Reply With Quote
Old 09-13-2003, 12:08 PM   #4532
Regional Moderator
Originally posted by Herminator
then say it
Well if you use a file, no matter how much it is filing
Just wanted a nice pic of how the cells sit, it's the kind of thing that helps others avoid muck ups.
Pics of my car will come in a few weeks....
don't have a digi cam of my own, if I did I'd probably annoy you with photo's although there isn't much to show at the moment, my cuda is just blue and close to standard.
Old 09-13-2003, 12:12 PM   #4533
Herminator's Avatar
Send a message via ICQ to Herminator
Originally posted by cHckbOY5
so no pics of the batt slots? and wat exactly is a metal file? never used one
metal file- rougher than a nail file, not as rough as a wood file
You just need a small flat sided one and possibly a rounded one for tight corners.
As has been said, it's to get the cells sitting nicely in the chassis, you want them low but not so low that they poke out the bottom of the chassis, where they can be damaged. Taking off the edge of the slots also stops them cutting into the heatshrink on the cells.
Don't know where Johnny got the idea it could tweak the chassis do you realise what tweak is?
Been on a boat catching barracuda's? make sure you file your fishing permit
Herminator is offline   Reply With Quote
Old 09-13-2003, 12:34 PM   #4534
Regional Moderator
lol there is no fishing off a 21 ft mastercraft but here is a nice picture for you of my boat dock and back yard
Old 09-13-2003, 01:06 PM   #4535
cHckbOY5's Avatar
Send a message via AIM to cHckbOY5
thats pretty nice backyard u got there
cHckbOY5 is offline   Reply With Quote
Old 09-13-2003, 01:18 PM   #4536
Jimmy Fukuyama's Avatar
NIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIICE!
Jimmy
Jimmy Fukuyama is offline   Reply With Quote
Old 09-13-2003, 04:20 PM   #4537
TC3
TC3's Avatar
Angry setup
today i did my first track test with the xplosion
but the car isnt as fast as my tc3
ok now i have to find a better setup, to make the xplosion the faster car
the first problem is: i dont have the hpi pistons, so i am using the std, i think 1mm, piston with 30 weight oil.
but that seems to be to heavy, if i compare it with the damping on my tc3...
on my th3 i had to run a soft setup on this track, like blue and silver springs with 40 weight oil.
i dont know what springs to use on my xplosion, i tried from 6,50 - 5,50. but i still dont have as much grip as on with the tc3.
it seems like the 5,50 are to hard for that track, 6,50 would be ok, but doesnt worke with that small pistons
the balance is ok, but i dont have enough grip, the car is pushing out of the corner a little.
any sugests?
my setup:
toe angel: fr: 0,5 re 2,0
camber: 1
caster: std
ride high: 5mm
no swaybar
shock and camberlink positon is std
there is a race at this track next weekend, and i have to win
but i have to run the xplosion
so i need a good setup, plz help!
the track is a 160m long aspahlt track, a little bumpy, i have to run take off cs27 tires.
pics of the track kan be found here: http://www.black-forest-racer.de/strecke.html
i ll do more testing tomorrow....
TC3 is offline   Reply With Quote
Old 09-13-2003, 05:26 PM   #4538
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
what are your droop settings (rebound)...and a bit more caster might help to....but the 1st thing you should work on is getting those pistion holes drilled out to 1.2mm ...
Trust me that Car "IS" faster when set up right...just takes a little bit of time to 1st figure it out..
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 09-13-2003, 06:50 PM   #4539
Randy Caster's Avatar
Trader Rating: 46 (100%+)
thats what i been trying to say there is really no filing . theres not enough to do to say your filing
I file the edges until the cells lay flat with the bottom of the chassis...
Old 09-13-2003, 06:57 PM   #4540
Nice back yard Joseph
Old 09-13-2003, 08:08 PM   #4541
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Looked back to find the R1 thread but couldnt...Anyone know what the main differences between the R1 and R2 are? Found an R1 pretty cheap just tyring to see if its worth buying or not.
thanks
ea
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 09-13-2003, 08:53 PM   #4542
Herminator's Avatar
thanks
ea
The R1 thread is just the other Barracuda thread, should be on the front page somewhere. It has evolved into an R2 thread. Not many of us have R1's, well standard versions
The differences between the two aren't huge, the shaft holders on the original use one bearing at each end instead of two, the chassis is slightly different so the cells are now closer to the center, the A arms are a little different.
Depending on how cheap it is it may be a good buy, there are a few good R2's selling second hand too.
Old 09-13-2003, 08:53 PM   #4543
thanks
ea
The chassis balance is not very good on a R1 and the sus a-arms are rather weak....but if you can find one you might not be able to get a drive system for it..since square has stopped making them ad also one Flag too and also you are stuck with the long a-arms...
but I still have that one R2 thats loaded for sale...
It will make it`s way to the for sale forum tonight.
-Dave
Old 09-13-2003, 08:57 PM   #4544
Team EAM
Ok Dave you talked me out of it!! Did you ever send me any pics of the Blue cuda you were telling me about? I am going to check on your GFX first thing monday morning.
[email protected]
eric a
Contact Us
Old 09-13-2003, 08:59 PM   #4545
Herminator's Avatar
-Dave
The Guru has spoken
if anyone knows it's JDM
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
