Old 09-09-2003, 07:01 PM   #4336
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Sorry...I should have stated that a little different. The pieces that are with the xenon and pal kits would be in these kits as well. The other alumn pieces I was referring to were hubs, servo mounts, battery braces, etc.
We are already setup to do anodizing...It would just be a matter of buying the colors that we dont have already.
ea
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 09-09-2003, 07:52 PM   #4337
cHckbOY5's Avatar
Send a message via AIM to cHckbOY5
if its the same quality n performance, who wouldnt get it for half the price... i kno i would hehe
cHckbOY5 is offline   Reply With Quote
Old 09-09-2003, 08:10 PM   #4338
cHckbOY5's Avatar
so let us know when u get the details
Old 09-09-2003, 08:16 PM   #4339
Regional Moderator
R/C Tech Charter Subscriber
I think you might go hungry on cuda chassis sells by the time you figure the set up cost and material and the alex car being a import and speedtech the lone seller of cuda parts in the states
i would think long and hard before i made that leap
plus pal,xenon,excel have some very very sweet products
Ko Racer is offline   Reply With Quote
Old 09-09-2003, 09:23 PM   #4340
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
ea
if you build it they wil come on both sides of the pond USA , Japan and Europe ..Quality and price will have to be a big thing though.. and your biggest thing would be alloy knuckes for the front that would accept a bigger OD bearing and then thicker shock towers.... so and so on..
just my to b its..
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 09-09-2003, 10:32 PM   #4341
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Originally posted by HEYALIGNMENTGUY
Hello all was thinking of changing spurs and pinions from 48p to 64. Does anyone know the correct conversion on how to do so?
Or better yet what are you useing to keep gear ratio's between 6.4 to 7.5
Any help at all or am I invisable
HEYALIGNMENTGUY is offline   Reply With Quote
Old 09-09-2003, 10:37 PM   #4342
Herminator's Avatar
Send a message via ICQ to Herminator
there is no conversion, you simply start using 64dp gears instead of 48dp
if you don't know that then I'd be very worried about you going to 64dp, it's harder to mesh and in the cuda you need an optional drive system of some sorts.
Herminator is offline   Reply With Quote
Old 09-09-2003, 10:45 PM   #4343
? why is there no conversion, I only run 27turn stock motors, I feel no need for PAL system.
Old 09-09-2003, 10:51 PM   #4344
Herminator's Avatar
48dp and 64dp gears refers to spur gears and pinions. they are two different sizes of gear teeth, so you buy a 48dp spur and use a 48dp pinion on the motor, try and mix 48dp with 64dp and you'll get a messed up spur imediatly. 64dp has finer teeth, this means they are weaker and more prone to stripping, which makes the gear mesh critical. The stock drivetrain simply isn't wobble free enough to be able to run 64dp as the shaft will move from side to side very slightly whilst rotating, changing the mesh as it goes, as so striping the teeth on the spur.
You need to do a little research before you go out and buy it.
Old 09-09-2003, 11:03 PM   #4345
No no no I think you got the wrong Idea. I am useing 72 spur and 25 or 26 pinion all at 48pitch I just want to quiet down my drive train noise on the R2 so I though going with 64Pitch would be a good choice
I think if I went and bought a 64 pich pinion and left my 48 pitch spur in it would make a terrible wracket
No worries K
Old 09-09-2003, 11:11 PM   #4346
Herminator's Avatar
No worries K
ok, but you wouldn't get away with 64dp on the kit drivetrain. If you get a PAL drive system you'd have to find a 64dp spur that fits, I think it's somewhere in the 90tooth range but I don't know for sure, haven't bothered with 64dp so far...
ad for reducing noise, 48dp can be reasonably quiet, but you have to work on other areas first.
Old 09-10-2003, 12:31 AM   #4347
HEYALIGNMENTGUY, if you want to quiet down the drivetrain, try the shim technique described by Dave. This pushes the bevel gear closer to the diff gear. If it's still noisy, then play with the shims on the sides of the diffs. My R2 runs quiet now after playing with the shims. I also run a 48p 72t Kimbrough spur gear.
Here's the original thread post: http://www.rctech.net/forum/showthre...him#post436683
Basically, you need to get the Kyosho #96644 8x10mm shim set. Depending on which version of the bevel gear, you apply 1 or 2 0.2mm shims. Also, you don't need to sand down the bevel or diff gears anymore. Remove only the extra flash material.
Headbanger is offline   Reply With Quote
Old 09-10-2003, 12:34 AM   #4348
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by Maj. Teeth
LOL! hopefully, I won't have to turn the throttle down to compesate for my lacking in skill when driving that motor. LOL
Dan
Didn't have to turn anything down tonight Dan! Congrats on the win and lapping the field
Old 09-10-2003, 12:37 AM   #4349
Ok guys I need some input. What type of demand would there be for a chassis kit along the lines of the Xenon, Speedway Pal, etc in the US if it retaild for HALF what the previously mentioned ones do? It would be just as high of quality and made in the USA. Before I chunk over the money to get it going I just want to make sure it will fly.
If it does then chassis for other cars will follow TC3, EVO's, etc. And possibly some alumn pieces down the road as well.
Just looking for some input.
eric anderson
That's exactly why PAL doesnt want their stuff in countries other than Japan. It would sell though to answer your question.
Old 09-10-2003, 02:02 AM   #4350
Well Put...that is the reason why it`s hard for these parts to get to the States and even harder pretty soon
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
