Alex Racing Barracuda R2 & R3 >
Like Tree4Likes
Old 09-07-2003, 09:44 AM
  #4186
fowlerJr68's Avatar
I just got one. What upgrades should i get for it?
Steve
fowlerJr68 is offline
Old 09-07-2003, 09:58 AM
  #4187
rocketron's Avatar
Trader Rating: 16 (100%+)
Steve
you just got an R2 cuda - great!
i would suggest that you get the alum shaft holders, the race the car a while to determine what you may find required. use 48pt gears and spurs between 69 and 72 in this configuration and you should be good to go. Use Kimbrough Spurs or other strong material the thin units won't last long.
rocketron is offline
Old 09-07-2003, 10:12 AM
  #4188
fowlerJr68's Avatar
thanx for the advice
nobody in my area has one.. so i'll be the only one.
what's a good setup for it?
Steve
Old 09-07-2003, 10:25 AM
  #4189
rocketron's Avatar
Steve
not sure if your outdoor or indoor but if you go to alexracingusa.com website and you'll find setup sheets to get you started.
oh one other item you may want would be springs - a couple stiffer and one softer. if your indoor on carpet you'll need to ask others here - but would expect you would want very stiff?
Old 09-07-2003, 10:42 AM
  #4190
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Ron - Will you be racing Tuesday?
Randy Caster is offline
Old 09-07-2003, 10:58 AM
  #4191
fowlerJr68's Avatar
thanx
Steve
Old 09-07-2003, 10:59 AM
  #4192
Fowler, You got PM
Old 09-07-2003, 11:09 AM
  #4193
http://www.rctech.net/forum/showthre...threadid=23951
Old 09-07-2003, 11:42 AM
  #4194
fowlerJr68's Avatar
can this car be competative stock out of the box?
Steve
Old 09-07-2003, 11:47 AM
  #4195
Regional Moderator
Steve
yes but i would invest in the upper shaft holders for the front and rear
Ko Racer is offline
Old 09-07-2003, 11:48 AM
  #4196
Regional Moderator
so when is the web going up for sale?
Ko Racer is offline
Old 09-07-2003, 11:49 AM
  #4197
Maj. Teeth's Avatar
Default Something for the Cuda Owners
Ok, So this morning Jimmy and I ran Pinky and it was really dialed just like my WEB Special. Now the only problem is Jimmy can't use Pinky to compete because he's contracted with another Factory so we'll be sharing Pinky for the time being.
I'm thinking to offer my WEB Special to the market since it's only had like 2 runs on it and is still considered almost brand new. Knowing that there aren't anymore made, I'm sure someone will be happy to take over the ownership of it.
Comes with everything that the Web Special has but also included a full set of Squat Dry Racing bearings which I've paid over $ 60 just to get it here from R10. I figured I'd post here just so you guys can have first shot at it.
Dan
Maj. Teeth is offline
  #4198
fowlerJr68's Avatar
to stabelize the shaft?
Steve
Old 09-07-2003, 11:52 AM
  #4199
Regional Moderator
Steve
yes to reduce flex in the shaft.
Ko Racer is offline
Old 09-07-2003, 11:54 AM
  #4200
fowlerJr68's Avatar
ok thanx
Steve
