Alex Racing Barracuda R2 & R3 >
Like Tree4Likes
Old 08-27-2003, 08:15 PM
  #3721
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
The car was pretty quiet, about the same as the blue car. Out of the corners the diff kept slipping no matter how tight I got it, so I always heard that.
The Kawada gear held up fine, I didn't have any 64 pitch pinions, so I was running the 48, but I picked up some 64 pitch pinions last night, so it's getting suited with 64 pitch now
Randy Caster is offline
Old 08-27-2003, 08:16 PM
  #3722
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by Randman
I'm going through it, the rear diff was having problems I had to make it way too tight for it not to slip. Also 2 of the Squat bearings seazed in the front knuckles, so I'm ditching those, and cleaning out all of the others. I think I can get the setup a lot better, just have to try some things out.
All 4 bearings went south.? I can get the replaced for free if you send them Back...I have a 30 Day return policy with them.... ( local track owner is in pretty good with them...)
Also were you using the standar Knuckles or the new Carbon ones.???
if you were using the carbon ones that Migh be part of the problem...because Alot of the Japanese Drivers have been trashing front bearings left and right with the new Knuckles.. to tight of a tolerance so they need to be reamed out ..
-Dave
JDM_DOHC_SiR is offline
Old 08-27-2003, 08:17 PM
  #3723
Sweet ...Did you give the other ones to Dave..?
Also with 64P in the Cuda it will be very Quite
-Dave
Old 08-27-2003, 08:19 PM
  #3724
-Dave
Actually just 2 of the 4 went south, the inside bearing on each knuckle, just 2 packs apart from eachother. I dont have the bearings to return, I had to crack them off the axle with vice grips. I'm just going to run the stock bearings in the knuckles, never had problems with them. I'm running the stock knuckles still, so that isn't the problem, I think it was something about the bearings...
Old 08-27-2003, 08:20 PM
  #3725
-Dave
Dave is hooked up with the Kawada gears, don't worry
I know it will quiet down even more with the 64 pitch, can't wait to make the switch
Old 08-27-2003, 08:22 PM
  #3726
Herminator's Avatar
A 7t!!!!
what have they put in the water over there Randman?
you certainly must be taking your brave pills, or is that stupidity pills...
I thought those kind of motor's were left for drag racers, those people who don't know how to turn
bearings going bad is worrying, and a dodgy diff too... you seem to have lots of problems, you should try the KISS method
Herminator is offline
Old 08-27-2003, 08:23 PM
  #3727
?? Really the bearing were shot..? Now I see why the Japanese Guys don"t use them that much..they just use the Stock bearings with Microlon and a slight drop of Royal Oil ..
Kind of sounds like the problem that I had with the Mega Buck$$ EXCEL Ceramics that I bought
-Dave
Old 08-27-2003, 08:25 PM
  #3728
Herminator's Avatar
crack them off with vice grips, sounds nasty indeed
Old 08-27-2003, 08:29 PM
  #3729
Herminator's Avatar
Jeez, buy expensive bearings and they go tits up, kind of worrying. I think I'll stick to my kit bearings, keeping them flushed out regularly in the integy vibrator dish and then letting a few drops of matrix oil soak in through the seals. They give me all the freeness I need when I do them all at once.
would have though expensive bearings meant more precision and less chance of failure, something odd going on there
Old 08-27-2003, 08:38 PM
  #3730
Originally posted by Herminator
A 7t!!!!
When Brian Kinwald, Barry Baker, Chris Tosolini, etc. run modified at SoCal, you need all the motor you can get...
  #3731
Don't remind me ...I cringe every time I look at the EXCEL ones that are in my Pit box
-Dave
  #3732
-Dave
Part of me still wants to try the Acer ceramic bearings...
Old 08-27-2003, 08:39 PM
  #3733
-Dave
What do you have left of that Excel kit?
Old 08-27-2003, 08:40 PM
  #3734
How about a nice 5T triple?? I have one that you might need to Kick start and need a comm cut after every run and new brushes... ........it's My Yatabe Arean 4min motor
man does it do a Number on batterys too....
-Dave
Old 08-27-2003, 08:41 PM
  #3735
about half for the Kit.. all of the others are shot
mainly the 15x10's all 4 and the Rear hub bearings
-Dave
