Alex Racing Barracuda R2 & R3
#3662
Have you got many long span setups you've worked on then? or do you tend to prefer the mid span?
What are your general starting points? like do you tend to have a stiffer spring at one end, or thicker shock oil? any commonly used shock positions?
#3663
#3664
Originally posted by RedBullFiXX
The Long Spans so nice, I wouldn't even be trying the MiD-Span if it wasnt for this funky banked oval circuit we have at SoCal, At every outdoor track I've been to the Long arm is supreme.
but the Long Arm set up is King out doors or on big Tracks..
-Dave
#3665
Originally posted by JDM_DOHC_SiR
yea about 12 Years.... now
8 more to go..
anyways you get back from that Race yet at So-Cal.. please let us know how things turned out
and what changes you had to do with that set up I gave you.....
I will be interseting to find out what you had to chage ...if anything..to get it to be on Rails.....
also Reb Bull to...
-Dave
also Reb Bull to...
-Dave
My setup didn't change too much from what you had, with the brushless motor, the car has horrible understeer. The HPI springs were too stiff, and the car pushes into corners, and exited them loose, I went down to a 1.4x5.5 in the rear, and a 1.4x5.75 in the front. Moved the front shocks inward 1 hole on the shock tower, and moved the rear shocks inward 1 hole on the rear A-Arms to try to get the car a little more aggressive into the turns. Dave's best laptime was a 10.2, and I hit a 10.4 in my main, so I was just a little off. I was actually having a great second qualifier, about 3 secs off of 1'st and 2'nd, but one of the bearings seazed in my knuckle (for the second time that night) and caused so much friction that the rim melted off of the axle and rolled away... I started 6'th in the main, and after a rough start went about a half lap down to the leaders (Steve, Dave, and Rod) by the end of the race Steve and Dave put me 1 lap down, but I'm not frustrated with how I did, once I get used to the understeer, or find a fix for it, I should be able to keep up with them. Dave and I had an awesome practice run together, so it gives me hope
#3666
Short arm and Mid arm is King indoors...
-Dave
-Dave
#3667
Originally posted by Randman
I'm going to buy some stiffer springs, my stiffest was a 1.4x5.5, I think I can get the car a little bit better with a bit stiffer.
the rayspeed srings are good choice
#3669
Originally posted by rc-zombies
KO...
what are you running F/R with the RS springs.... I just picked up some Red and White...'coz I saw them here at one point and haven't mounted them yet....
KO...
#3670
Originally posted by Ko Racer
dave told me to run the red front and white back and they are some nice springs and i also installed the new yoko shock caps with rayspeed bladders so im ready for this weekend/
let us know how the Yok caps and RS bladders work out... I've got a set waiting to be installed.
#3671
With the RS did you have to change the spring cups? RS springs are longer...
#3672
Im using the yoko spring cups and they seem to fit good but if there is someone with more info on this please fill us in before i hit the track with it
#3674
