Alex Racing Barracuda R2 & R3
#3436
Originally posted by Headbanger
1.5mm
2.0mm
2.5mm
5.5mm socket
7.0mm socket
As for the phillips screws, I recommend you replace them with stainless steel or titanium. The torx screws are harder to find and you would need a T10 torx driver.
Depending on the brand of pinion gear you buy, you may need a US measurement driver for the set screw. I can't remember what the size is.
1.5mm
2.0mm
2.5mm
5.5mm socket
7.0mm socket
#3438
where can i get the screws?
#3439
Originally posted by cHckbOY5
but wat do i need just to build it for now? is there any discount if u get the set?
HUD 190100 Allen Driver Set 8 Pcs1.5,2,2.5, 3.05,.063,.078,.093
HUD 190170 Socket Driver Metric Set 6pcs
#3440
wat about integy tools?
#3442
i dont see the hudy sets, i only see individual
#3443
On mine I use stainless screws from RCscrewz.com. You can buy the screw kit or the screw packs.
Here are the quantity and sizes of the flathead from the manual:
24 - 3x8
19 - 3x10
8 - 3x12
4 - 3x20
#3445
You'll also see the sockets come in a set, too. Some you use, other you won't.
http://shop.hudy.net/info.php3?ID=60...252efbc9cbbd61
http://serpent-usa.com/hudy/hud575_1.html
#3446
do u actually save by getting set? is it better to get set even if i dont use all?
also, y do i need to change screws? isnt the cuda light enough?
#3448
Originally posted by Randman
The reason for changing screws is to get away from the phillips head junk that comes with the kit.
rocketron has a nice looking stainless set, so if you're gonna get screws, get em through him.
#3449
so wat r they gonna be replaced with? hex? also do i get flat or butten?
#3450
so wat do u recommend?
