Alex Racing Barracuda R2 & R3 >
Like Tree4Likes
Old 08-20-2003, 08:01 AM
  #3376
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Originally posted by cHckbOY5
wat to get first, PAL or al shaft holders? or aluminum hubs?
I was running stock with just the alloy shaft holders and was doing fine once I put on the Robinson TC3 gear. For stock, the PAL really isnt a necissity. The only hopups I had on the car were alloy shaft holders, offset pivot balls, and clamping wheel hexes...
Randy Caster is offline
Old 08-20-2003, 12:16 PM
  #3377
cHckbOY5's Avatar
wats the offset pivot balls? the gold ones?
cHckbOY5 is offline
Old 08-20-2003, 12:44 PM
  #3378
rc-zombies's Avatar
Lets you adjust toe-in or out
rc-zombies is offline
Old 08-20-2003, 01:09 PM
  #3379
Gazza_D's Avatar
Unhappy Play in Aluminium Hubs?!?!?!
Can anyone help???
Just built my Web R2, real easy to build thank god the missus can translate Japanese
Have a couple of questions that may have been lost in translation so to speak.
I have fitted the Aluminium C hubs on the front but there seems to be a hell of a lot of play front to back along the hinge pin
Would not expect 2 mm of movement from a brand new kit????
Would normally shim out the play, but, is this normal????
Second concerns the PAL main shaft, seems there is a lot of end float that causes the metallic clicking noise that can be heard from the drive train. Could possibly cut down a silicone washer to take up the slack or is ther supposed to be end float???
Cheers
Gaz
Gazza_D is offline
Old 08-20-2003, 01:21 PM
  #3380
Herminator's Avatar
Default Re: Play in Aluminium Hubs?!?!?!
Originally posted by Gazza_D
Can anyone help???
Cheers
Gaz
It's odd that there is so much play in the hubs, I don't have alloy ones but the kit items were a perfect fit for me and only recently I put a washer in to take out some play from all the wear.
I don't think there should be much back and forth movement in the drive system, a ruber washer in the ends is normaly used to fix it.
Herminator is offline
Old 08-20-2003, 02:20 PM
  #3381
rc-zombies's Avatar
Default T-10 TITANIUM SCREWS..
Found some on RainbowTEN.
Waiting for reply back on how many per pack. 320yen=$2.72usd.
I hope the price is not for one Screw
3263432637687,,,320yen,A010 TITANIUM HEX ROBE T-10 COUNTERSUNK SCREW 3x8
3263432637688,,,320yen,A011 TITANIUM HEX ROBE T-10 COUNTERSUNK SCREW 3x10
3263432637689,,,320yen,A012 TITANIUM HEX ROBE T-10 COUNTERSUNK SCREW 3x12
3263432637690,,,320yen,A013 TITANIUM HEX ROBE T-10 COUNTERSUNK SCREW 3x15
3263432637691,,,320yen,A014 TITANIUM HEX ROBE T-10 COUNTERSUNK SCREW 3x18
3263432637692,,,320yen,A015 TITANIUM HEX ROBE T-10 COUNTERSUNK SCREW 3x20
3263432637693,,,320yen,A016 TITANIUM HEX ROBE T-10 COUNTERSUNK SCREW 3x25
3263432637694,,,320yen,A017 TITANIUM HEX ROBE T-10 ROUNDHEAD SCREW 3x6
3263432637695,,,320yen,A018 TITANIUM HEX ROBE T-10 ROUNDHEAD SCREW 3x8
3263432637696,,,320yen,A019 TITANIUM HEX ROBE T-10 ROUNDHEAD SCREW 3x10
3263432637697,,,320yen,A020 TITANIUM HEX ROBE T-10 ROUNDHEAD SCREW 3x12
3263432637698,,,320yen,A021 TITANIUM HEX ROBE T-10 ROUNDHEAD SCREW 3x15
3263432637699,,,320yen,A022 TITANIUM HEX ROBE T-10 ROUNDHEAD SCREW 3x18
3263432637700,,,320yen,A023 TITANIUM HEX ROBE T-10 ROUNDHEAD SCREW 3x20
3263432637701,,,320yen,A024 TITANIUM HEX ROBE T-10 ROUNDHEAD SCREW 3x25
Old 08-20-2003, 02:29 PM
  #3382
Yep, the titanium nitride pivot balls...
Old 08-20-2003, 02:32 PM
  #3383
Can anyone help???
Cheers
Gaz
I believe the Xenon hubs do need a little bit of shimming, but that's not a bad thing, it allows you to adjust the wheelbase.
As for the PAL shaft, use O-Rings to get it in the right place, you want a little bit of front/back play in the driveshaft, dont get it to where there's none...
Old 08-20-2003, 02:33 PM
  #3384
Default Re: T-10 TITANIUM SCREWS..
[QUOTE]Originally posted by rc-zombies
[B]Found some on RainbowTEN.
I was wondering how many screws those packs have in them as well. Please let us know when you get a reply back, I want spare screws...
Old 08-20-2003, 02:35 PM
  #3385
rc-zombies's Avatar
Default Re: Re: T-10 TITANIUM SCREWS..
[QUOTE]Originally posted by Randman
[B]
will do.
Old 08-20-2003, 02:49 PM
  #3386
cHckbOY5's Avatar
YAY just got my R2... box is pretty long
cHckbOY5 is offline
Old 08-20-2003, 02:53 PM
  #3387
rc-zombies's Avatar
yea..and half empty.
Old 08-20-2003, 02:55 PM
  #3388
The car has fewer parts than anything I've owned, but the box is huge...
Old 08-20-2003, 03:04 PM
  #3389
cHckbOY5's Avatar
man japanese intructions... lol, this is gonna be tough im gonna need ur guys' help. wats the stuff in the small tube for?
cHckbOY5 is offline
Old 08-20-2003, 03:07 PM
  #3390
Gazza_D's Avatar
Just checked the amount of play on my vernier..... 1.1mm on both sides?!?!?!? Funny thing is there is no play in the rear ones. Will shim it up and see how she handles.
Thanks Herm, RM, I'll let you know how things go trackside on Friday.
Hope it doesn't rain
Gazza_D is offline
