Alex Racing Barracuda R2 & R3 >
Like Tree4Likes
Old 08-10-2003, 12:01 PM
  #2716
Default Battery posts
I tried using the bottom xray battery posts with 3mm hex screws. The height seems just about right, but you have to use the opposite holes and flip the R2 battery strap. The plastic strap is a little soft and I thought maybe the batts would come loose in a hard crash, so I went back to taping. The Aluminum strap might work better, but I don't have one and Speedtech is out of them. Anyone want to try this?
A mod I'm considering is getting the Tobee Craft Cell separator for the Yok SD. Basically these mount near the edge of the chassis and would prevent the batts from falling out.
Headbanger is offline
Old 08-10-2003, 12:03 PM
  #2717
Originally posted by John_S
ok thanks for the info do you ahev an item number for the straping tape? please and thankyou
You should be able to find the fiberglass strapping tape at any local hardware/shipping store, cheap.
Old 08-10-2003, 12:20 PM
  #2718
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Default Cell Tape
If your going to tape, do it right....
Tamiya Glass Tape (Black) Item 49106
They used to have Blue, and red tape, now all they have is the black stuff. The Tamiya tape is thicker than what you will find in most hardware stores, Most of us run one piece all day, so its durable too. make sure you round the edges a little on the chassis where the tape bends around it
RedBullFiXX is offline
Old 08-10-2003, 12:40 PM
  #2719
Maj. Teeth's Avatar
Default Re: Cell Tape
May I ask where you bought those tapes? I couldn't find any at LHS. I must admit those are really nice and excellent to work with.
Dan
Maj. Teeth is offline
Old 08-10-2003, 12:45 PM
  #2720
Default Re: Re: Cell Tape
Dan
Check with SteveTechRC
Tamiya Glass Tape
Old 08-10-2003, 01:01 PM
  #2721
Maj. Teeth's Avatar
Default Re: Re: Re: Cell Tape
Tamiya Glass Tape
Thanks. Steve is OOS but I'll check with him again.
Dan
Old 08-10-2003, 01:03 PM
  #2722
John_S's Avatar
exelant thanx rbf i just emailed steve to see if he can add it to my last order that i orderd 2day hope he will be able to
John_S is offline
Old 08-10-2003, 03:16 PM
  #2723
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Hey Dave..
You should see if steve can get the new Glass Tape fron Xenon..!! It`s Super strong and comes in Blue , normal and Black
I swear by the stuff..!!
-Dave
JDM_DOHC_SiR is offline
Old 08-10-2003, 05:15 PM
  #2724
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Cool! I hope to be kept inform when the 3mm PAL chassis is available for the Web. I'd like to have one on spare, eventhough the Web's 2.6mm is good enough. Never know when the thicker ones will be needed.
Dan
Dave is the update man
Randy Caster is offline
Old 08-10-2003, 05:16 PM
  #2725
been there, tried that, doesn't fit....But the Tamiya strapping tape does a nicer job anyway
Rod told me that Tamiya discontinued their strapping tape, and of coarse, he bought like 5 of the last rolls
Old 08-10-2003, 05:17 PM
  #2726
Originally posted by JDM_DOHC_SiR
Hey Dave..
-Dave
Hopefully Steve can get that stuff, I like the black tape, but the Tamiya stuff was gone before I learned about it...
Old 08-10-2003, 05:57 PM
  #2727
rtypec's Avatar
That stuff is gold If you were standing there and they said, by the way, we only have so many left, you'd buy some too, besides I didn't buy the last ones...there were like 17 rolls left. I just liberated a few of them so that I have an ample supply while looking/waiting for a substitue.
That xenon stuff sounds interesting though
rtypec is offline
Old 08-10-2003, 06:23 PM
  #2728
I'm gonna try to get the Xenon stuff, hoping it's just as good...
Old 08-10-2003, 06:57 PM
  #2729
NMRCDude's Avatar
I have never really used Strapping tape that much. Is it a one-time use type of thing? Or can you use the same piece for an entire day?
NMRCDude is offline
Old 08-10-2003, 07:03 PM
  #2730
Took cuda out to race today did rather well, got better with each heat. Turned a 19 in the first one, did a 20 in the second. 21 in the third
they combined times so I qualified 2nd. They desided to go with a AAA main set up, loads of fun I must say, I came in third after it was done.
A lot of people never even heard of the car, had a lot of looky loo's
Ask me where the could get one, I pointed at my Speed tech T shirt I was wearing "Thanks Steve"
I do have a technical question, seems that the spur gear is taking a beating, even running stock motors.
Is the PAL drive system the best fix or would the aluminum shaft holder?
I run standard 72 spur and 48 pich pinions.
Many thanks are appreciated
HEYALIGNMENTGUY is offline
