Old 08-07-2003, 10:38 AM   #2566
forty6's Avatar
I broke a couple already, totally my fault. I am thinking of getting the Xenon aluminum c-hub for the cuda if it fits since nobody is releasing one yet for the SD.
forty6 is offline   Reply With Quote
Old 08-07-2003, 10:42 AM   #2567
rc-zombies's Avatar
the hinge pins are of differenct size... the cuda uses a larger dia. hinge pins. and on the SD.. you have the option of mounting in upper or lower position for tuning... on the Cuda..only 1 position.
Stay with the SD C-blocks.... Team Sukuki will eventually come out with one and I'm sure Yokomo will release a graphite version.
Old 08-07-2003, 10:50 AM   #2568
forty6's Avatar
Thanks zombies. I'll probably need to be more careful staying off the boards for the meantime.
Old 08-07-2003, 10:51 AM   #2569
rc-zombies's Avatar
I have the same problem... those boards always gets in my way...
Old 08-07-2003, 10:53 AM   #2570
forty6's Avatar
Yep, they freaking move when you try to avoid them.
Old 08-07-2003, 02:30 PM   #2571
rc-zombies's Avatar
Just got done assembling the shocks...
and in the process almost lost one of the those spacers and wire spring clip. luckily I found them.
It's not as silky smooth compared to the Yok SD shocks. the shock shaft doesn't move in & out smoothly. Feels like something is clamping around it... is it the 1mm spacer? I used the clear O-rings and also applied the usual green slime on it. Is the 1mm spacer neccessary?
Please advice...thanks.
Old 08-07-2003, 03:37 PM   #2572
I think the problem with Cuda shocks is that there is no room for the compressed oil to go. Normally, you see bladders or foam rings in the shocks so when the piston moves in, the displaced oil has somewhere to go. The build instructions recommended #200 and #100 oil which translate to 15wt and 5wt.
I have tried the HPI #2 piston with 40wt oil and it seems good but still the shocks feel stiff. I just put on the new some Yokomo (blue) caps with Rayspeed yellow bladders and used 40wt oil and I have to say they feel much better.
Headbanger is offline   Reply With Quote
Old 08-07-2003, 03:45 PM   #2573
rc-zombies's Avatar
I don't even have oil in the shocks yet... and they feel very stiff...
Old 08-07-2003, 03:56 PM   #2574
What pistons are you using? Hopefully not the black ones off the parts tree. There should have been white teflon ones in your kit. I found some HPI #2 with bigger holes.
Old 08-07-2003, 04:04 PM   #2575
rc-zombies's Avatar
HPI #2piston....
and I didn't find any white teflon ones..
I'm going take them apart again and rebuild... I did notice that the plastic part ( the first part that goes in ) is not totally flush. I may have to push that part in harder...
Old 08-07-2003, 04:21 PM   #2576
Herminator's Avatar
Send a message via ICQ to Herminator
You should have some white pistons somewhere, and the first spacer in the shock should fit snugly, showing out the other side. My shocks were nice and smoothat all times, just found using the bleed screws was a right pain, if they are stiff when full of oil but fine without oil then you haven't bled enough oil out.
They should be as good as Yokomo shocks because thats what they are essentialy
The 1mm spacer you're talking about, is that the one that goes on the rear shocks only or the one in the base of all four shocks?
You could really do with Dave's photo's of the shocks......
Herminator is offline   Reply With Quote
Old 08-07-2003, 04:30 PM   #2577
rc-zombies's Avatar
the 1mm spacer is the one sandwich between the O-rings... I think I found the culprit...yes its the first plastic part that shows. It was not pushed out all the way. and was at an angle making it tight.... now all 4 are a little smoother. Still not as smooth as Yokomo shocks... I think I'll swap out the clear O-ring and replace them with Rayspeed yellow O-rings... which were silky smooth on my SD. Yea... bleeding the shocks is a pain... I'm going to go with the New Yok caps and RaySpeed bladders.
would like to see Dave's shock photos... that would be helpful...and there's too many pages to search for it..
Old 08-07-2003, 04:33 PM   #2578
Herminator's Avatar
he's not actually posted pics yet, he said he'd do it a couple days ago but then had camera problems, which he aparently fixed....
must be busy playing with his cuda's
Old 08-07-2003, 04:34 PM   #2579
rc-zombies's Avatar
yea...either he's out playing or still in bed.... I think it's early morning now in Japan...
Old 08-07-2003, 09:06 PM   #2580
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I had the same problem with the shafts binding a slight bit. It is propably the first spacer causing the bind, be sure it's put all the way flush. I also use MIP O-Rings, they are much smoother.
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
