Old 07-31-2003, 09:01 AM   #2206
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by JDM_DOHC_SiR
IC..
I dread the day that I have to go back to the states were I have to run 75mhz...!!!!! ... I have a Radio thats on Japan 27mhz that I will use... but NEVER EVER will I run 75
-Dave
I'm on 40mhz
Old 07-31-2003, 11:43 AM   #2207
SpeedTech's Avatar
Here's my take on radio glitches. First of all, it is the worst thing to deal with on a race day. I battle radio problems with my M8 for almost 2 months. I even took it to Airtronics and they said all three of my receiver, 8 sets of crystals and radio have no problem. Took it to the track the next week, still glitch city.
The problem was simply the fact that my module was old. It was the original module that came with the radio when I bought it 2 years ago. After talking to some of the factory racers, the first thing they recommand is 27Mhz (I was on 75mhz), and the following are information I gather from them:
Futaba modules will go out anywhere from 6 months to a year
Airtronics is about 1 year to 1 1/2 year. And the other brands are about the same (those that use a module). Sometimes this is not a problem at certain tracks, but at tracks where there are a lot of interference (for example, metal fence around the track, florecent light over head...etc.) it can create severe interference. And the reason why Airtronics was not able to detect any problem is because when they are testing equipments, it is most likely in a "friendly" environment for the radios.
Simple solution is to just change the module. I switch to a 27mhz module, with a 27 mhz receiver on the same M8 radio system and had not had a hit since, even when I attended TCS in June where there was over 100 entires.
Other things that can cause glitching are blown capacitors on motors (espcially stock motors). Epic motors, which have surface mount capacitors can blow out, and you won't even know it. You can remove them, and install normal capacitors on them, and it should work fine. Also look into trying different receiver, crystals, and servo (servo glitches are rare, but it does happen), and speed controls. Make sure to change one thing at a time so you can utilize a process of elimination. Don't be surprised that sometimes it can be a combination of two things (seems to happen to me all the time )
Lastly, make sure all your wiring is good, and your radio equipment is clean to began with (as in have it tuned on a regular basis).
Cars don't cause glitches, it will however, tell you how "clean" your radio equipment is
Hope that helped!
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 07-31-2003, 11:47 AM   #2208
Regional Moderator
ImGoinRCn's Avatar
Send a message via Yahoo to ImGoinRCn
I run 75 mhz and a GT-7 and have not trouble at all and I'm not using a KO radio...
When all else fails, aim for the quarter panel.
Several oval and off road vehicles
and a legend car nicknamed Kidney Stone.
X Factory R/C SCX-60CF
X Factory R/C X-6
ImGoinRCn is offline   Reply With Quote
Old 07-31-2003, 01:01 PM   #2209
Regional Moderator
R/C Tech Charter Subscriber
Originally posted by Randman
I'm on 40mhz
they let you race with a 40 mhz here in the states
Ko Racer is offline   Reply With Quote
Old 07-31-2003, 01:10 PM   #2210
SpeedTech's Avatar
Hi Guys,
Much to my surprise...a little (actually, a huge) package arrived today. I will be doing some website updates on the Alex Racing section tonight. Keep checkin the website
Steve Wang
Old 07-31-2003, 01:13 PM   #2211
Regional Moderator
Originally posted by SpeedTech
Hi Guys,
Steve Wang
steve if you got any pit towels in hold me one back
Old 07-31-2003, 01:31 PM   #2212
Herminator's Avatar
Send a message via ICQ to Herminator
OOhh, suprise packages, they're always nice
Herminator is offline   Reply With Quote
Old 07-31-2003, 01:52 PM   #2213
rc-zombies's Avatar
Hi Guys,
Steve Wang
Yea!!!!
Steve just informed me that Web Specials were part of that shipment.... mine is on its way to its new home...
Thanks again Steve....
Old 07-31-2003, 02:57 PM   #2214
SpeedTech's Avatar
KO,
Sorry, no pit towels this time
Zombie,
No problem! is on its way.
Some of the new stuff we got:
Hard material mid-span and regular span Arms, knuckle/c-hubs, and double one-way bearing front one-way units.
Steve Wang
Old 07-31-2003, 03:52 PM   #2215
JohnA's Avatar
Steve
The double bearing one-way. Is that different to the one supplied with the R2 kit?
JohnA is offline   Reply With Quote
Old 07-31-2003, 07:35 PM   #2216
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by JohnA
Steve
Yep it has 4 one way bearings vice 2 oneway bearings and bushings....much stronger..
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 07-31-2003, 07:37 PM   #2217
Hi Guys,
Steve Wang
Drive Systems.???
in Black...or.anyother color...
and I`ll ask the EXCEL Question again
Can you get the stuff for the CUda from them
-Dave
Thanks!!
Old 07-31-2003, 07:38 PM   #2218
Default Re: Re: Re: GT7 on cuda
Is that the S9450 servo Dave?
Nope
S9550
Old 07-31-2003, 07:47 PM   #2219
Actually that is the first thing I did, and when I do that, there is very little drag on either end, maybe a little more on the rear though. This thing has me puzzled...
I can fix it eheheheh
-Dave
BTW you have a PM
Old 07-31-2003, 07:48 PM   #2220
I just sign up on channel 65. Never said it was on 75mhz
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
