Alex Racing Barracuda R2 & R3 >
Like Tree4Likes
Old 07-08-2003, 09:15 PM
  #1501
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Default Re: New Cuda Goodies
Originally posted by JDM_DOHC_SiR
I should have a few new items that I'll take picture of tonight for you guys..to take a look at.... also Speed Tech should be getting this item in soon too...( I think )
Do you all know what .... it is.???
-Dave
I dont know what it is, but I want to know! Dont keep us waiting too long
Randy Caster is offline
Old 07-08-2003, 09:30 PM
  #1502
JohnA's Avatar
whoops wrong thread!
JohnA is offline
Old 07-08-2003, 09:39 PM
  #1503
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
hahahaah
it's OK John
JDM_DOHC_SiR is offline
Old 07-08-2003, 09:46 PM
  #1504
JohnA's Avatar
Keeps the 'Cuda thread to the top
JohnA is offline
Old 07-08-2003, 10:00 PM
  #1505
Not that this thread ever falls down
Old 07-08-2003, 10:04 PM
  #1506
cHckbOY5's Avatar
man now im leaning toward this car instead of the sd
... but will part support continue for this car or after couple month will it all disappear?
cHckbOY5 is offline
Old 07-08-2003, 10:08 PM
  #1507
Seems like Speedtech is pretty dedicated to parts support, I dont think it's going to die down at all, if anything, it will get better. And like I've said, I sold the SD because you need parts support, the R2 seems to be much more durable.
Old 07-08-2003, 10:10 PM
  #1508
Steve at Speed Tech always makes sure that spare parts are always available...and he trys to get the latest hops ups from Japan for it too..
...this car is here to stay..
Old 07-08-2003, 10:13 PM
  #1509
Yeah, I am really glad that Steve gets all the parts he can from Japan, makes it really easy to get the best stuff.
Old 07-08-2003, 11:55 PM
  #1510
cHckbOY5's Avatar
is this car really more popular than evo3 n sd in japan?
cHckbOY5 is offline
Old 07-09-2003, 12:29 AM
  #1511
It`s all about the same between them ...but the Cuda users are now growing..because a lot of the SD users are switching over to the R2....
.. the Japanese Sports man Championship is this up and coming weekend...so it will be interesting to see what car wins this year...last year it was the R1 Barracuda..... now that ALEX has the R2..it should be really interesting to watch..
-Dave
Old 07-09-2003, 12:49 AM
  #1512
cHckbOY5's Avatar
ooo... go cuda!!!
cHckbOY5 is offline
Old 07-09-2003, 04:13 AM
  #1513
Pandora's Box's Avatar
Does the aluminium shaft holders improve performance? Possibly it could improve drive train efficiency. Could there be other reasons? Are the stock plastic holders good enough for competition?
How do you access pages of a thread that aren't displayed at the top?
Pandora's Box is offline
Old 07-09-2003, 05:29 AM
  #1514
Herminator's Avatar
The alloy shaft holders will improve efficiency by reducuing shaft wobble, so the mesh between all the gears will remain constant and no damage should be done. The plastic holders are fine, you need make sure you build the chassis with no tweak with either shaft holders but it's more important when using the plastic versions. If you're running a modified motor though you would be best to get the Speedway PAL Drive System, this holds the spur gear closely on both sides so that there is no wobble and the spur gear mesh is as accurate as possible, you do have a little more drive train weight and one more bearing to add drag but it's worth the tiny sacrifice.
to read previous pages you can click on the page numbers a couple at a time or you could go to the start and read them all again, enjoy the 50 pages you may want to do a search for a certain word or topic and select display the results as posts, instead of the normal thread result it gives you.
Herminator is offline
Old 07-09-2003, 05:41 AM
  #1515
highwayman's Avatar
is there a difference in the handling between the PAL kit and the R2 kit?
thanks - jason
highwayman is offline
