Old 12-29-2006, 07:02 PM   #1
wingswest328's Avatar
Send a message via AIM to wingswest328
Default Soldering Flux
I need some flux for soldering. I have some stuff but it says not for electrical use. What are some good companies? I would rather a paste or something that is not liquid.
Thanks,
Cameron
wingswest328 is offline   Reply With Quote
Old 12-29-2006, 07:10 PM   #2
Centerline Racing's Avatar
Trader Rating: 33 (100%+)
Default What For?
Why do you need flux?
All the soldier I have used uses a flux core within the middle. This has always been sufficient, for me at least, when soldiering R/C stuff.
Maybe you are soldiering something different from R/C?
Allan
Centerline Racing is offline   Reply With Quote
Old 12-29-2006, 07:16 PM   #3
No, its r/c but it just seems that when I have used the flux I do have, which is not for electrical it makes tinning a hell lot more easier. That is just me.
Old 12-29-2006, 07:25 PM   #4
I understand.
I had that type of issue. I purchased a decent quality soldiering station that has an adjustable temp dial. It solved all my problems. Now I just dial in the temp I want based on what I am soldiering.
Good Luck
Allan
Old 12-29-2006, 07:36 PM   #5
you can find flux at radio shack. a good electrical solder already has flux in it.
i use Kester "44"
baih is offline   Reply With Quote
Old 12-29-2006, 07:45 PM   #6
Iceracer's Avatar
Clean the surface thoroughly before soldering. Emery cloth, dremel and wire wheel and stainless mini brush are all usefull.
Iceracer is offline   Reply With Quote
Old 12-29-2006, 08:54 PM   #7
Ok. I do have a hakko 936 station but I really haven't got around to using it. I guess it is coming out the box and I will see what I can do. Is the deans pro Solder any good or is there better?
thanks
Old 12-29-2006, 09:15 PM   #8
Default Flux
Opinions and techniques both vary; but I prefer soldering with a good flux. You may have to try more than one to find one that suits you, but I prefer more acidic fluxes. And by the way, I was trained and certified to solder on NASA satellites. Thanks; Ernie P.
Ernie P. is offline   Reply With Quote
Old 12-29-2006, 09:38 PM   #9
* EDIT: I meant to say what flux do you recommend? *
Old 12-29-2006, 11:41 PM   #10
is this soldering iron efficent enough to be able to solder battery packs and other things
C_Suzuki is offline   Reply With Quote
Old 12-30-2006, 05:36 AM   #11
Skiddins's Avatar
I use something like this, has a tip a bit like a large felt tip pen which means you can be pretty accurate with it, and combined with my 80W Weller soldering irong I can solder a battery bar to a cell in less than 1 second
Flux Dispensing Pen
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-30-2006, 12:08 PM   #12
EddieO's Avatar
R/C Tech Charter Subscriber
We sell small bottles of liquid flux at www.teambrood.com
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Old 12-30-2006, 05:07 PM   #13
tmaxxking's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to tmaxxking
Default .
i use lucky bobs acid flux
http://www.gofastest.com/luckybob/Products.htm
i used it to build 1/24 slot car drag cars
best i have ever used
eddieo's flux from my guess is real close to the flux we use
FEEDBACK LINK
rctech.net/forum/showthread.php?t=106423
tmaxxking is offline   Reply With Quote
Old 12-30-2006, 11:39 PM   #14
burbs's Avatar
Send a message via AIM to burbs Send a message via Yahoo to burbs
flux works great for building packs.. it allows less solder to be used, and a more solid connection.. If your having problems re soldering, you can just tin the tip with some fresh solder and it will work fine.. however you will eventually have a glob of solder.. i always yry to use as little as possible, but still have a good connection..
I also dip my solder tip in fulx before i sponge it.. seems to help it stay clean and pre tinned better..
burbs is offline   Reply With Quote
Anyone have the HPI E-Firestorm Flux brushless RTR truck? pgeldz Electric Off-Road 9 10-29-2008 08:52 AM
HPI E-Firestorm 10T Flux RTR DSX-2 Brushless Cain Electric Off-Road 0 05-11-2008 11:24 AM
flux removal on battery cells BrainTeased Electric On-Road 17 06-24-2006 09:40 AM
soldering? SPC Racer Electric On-Road 13 10-02-2004 05:46 PM
Soldering help??? zachzachz Electric On-Road 4 11-28-2003 12:27 PM
