Old 03-03-2003, 03:17 AM   #1
bruisedwillis's Avatar
CE Pit Bull
What will happen if I were to use it on 3300mAh batteries, it says 3000mAh compatible..
bruisedwillis is offline   Reply With Quote
Old 03-03-2003, 09:23 AM   #2
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
You should not have any problems using it.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 03-03-2003, 09:28 AM   #3
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Default Pit Bull Charger
I do have ones and the ce pit can charge any 3000 0r 33000 battery on the market.. The 3000 and 3300 are the same battery just that the 3300 are bigger than 3000...Good luck
OVA is offline   Reply With Quote
Old 03-03-2003, 02:30 PM   #4
CGR
CGR's Avatar
I regularly charge 3300 with my Pitbulls. I seem to recall one of their techs saying it can charge 4000+ when they come out. YOu can always give them a call, they are real helpful
CGR is offline   Reply With Quote
Old 03-03-2003, 05:19 PM   #5
sponger's Avatar
CGR, Where in Az do you race??? I'm tring to find a track near Kingman and Bullhead City
Sponger
sponger is offline   Reply With Quote
Old 03-03-2003, 07:18 PM   #6
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Originally posted by bruisedwillis
Will it shows the actual capacity, after 3000 mah? Or reset to 0000mah
It will show cell capacity for 3300's. I haven't had a problem with mine not showing it.
-Troy
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 03-03-2003, 07:36 PM   #7
Old 03-04-2003, 06:20 AM   #8
Default 3000 HV CHARGING
SANYO 3000HV CHARGING
GUYS I NEED HELP IN CHARGING MY SANYO 3000HV. WHAT'S THE IDEAL CHARGE RATE,AMPS AND THRESHOLD IN CHARGING 3000 SANYOHV AND 2400 TAMIYA STICK PACKS USING A PITBULL CHARGER.......................TNX
max428 is offline   Reply With Quote
Old 03-04-2003, 06:53 AM   #9
dtm
dtm's Avatar
Send a message via ICQ to dtm
Charge capacity is an "almost" useless figure. It merely gives you the calculated charge that was given out by the charger during charge. This is NOT the capacity which your cells give out on discharge.
It will carry on going after 3000mah and not reset to 0000........
dtm is offline   Reply With Quote
Old 03-04-2003, 08:04 AM   #10
RCTech Member #2
TSR6's Avatar
Agreed. It's only useful if you know the discharge state of your cells. If you discharge the pack down to 5.4v, you should be fairly close on the Mah numbers. If you do not discharge your cells after running them, who knows where it may be.
Troy
RCTech Member #2
Old 03-04-2003, 08:13 AM   #11
OVA
OVA's Avatar
hey Max428
You can chrg yours sanyo 3000 battery at 6amp cutoff .03
and for 2400 5 or 6 amp cut off .05 or .07 no problem good luck
Old 03-04-2003, 08:16 AM   #12
OVA
OVA's Avatar
max428
Don't forget NIMH and NI CA setting too( which battery ) for chrg
Old 03-04-2003, 09:48 AM   #13
CGR
CGR's Avatar
Sponger, I race at SRS in scottsdale, sorry but dont know of any track around kingman or bullhead. Vegas might be the closest.
Old 03-04-2003, 10:04 AM   #14
sponger's Avatar
Thanks CGR
Old 03-04-2003, 07:12 PM   #15
Default 3000 sanyo hv
thanks a lot ova..........
Pit Bull mackin R/C Items: For Sale/Trade 0 11-27-2007 01:19 PM
pit bull x3 ACEDEAN R/C Items: For Sale/Trade 3 10-17-2007 11:39 AM
F/S Pit Bull X3 Fabulous R/C Items: For Sale/Trade 6 03-25-2006 10:37 PM
CE Pit Bull X3 squarehead Electric On-Road 3 08-27-2005 06:49 AM
Pit Bull X3 Dolce R/C Items: For Sale/Trade 3 02-22-2005 10:54 AM
