2400 Battery question...
Hey all,
Quick question was are good numbers on a 2400 6-cell pack... Here are the numbers I am getting from my packs off my millenium 2417 mah / 10.13 volts / 79734 joules Is this a good / average / bad pack??? Thanks, John |
that 2417 mAH are charge number or discharge number.
The charge numbers don't matter at all :) If you can, get them discharged on something like a T35, then you can tell how good they are.
I think those numbers are the ones that the millenium displays after the charge.
I'd say that is an average pack. What amperage did you charge at? I get around the same results but my battery peaked at 9.7volts. :) |
The most accurate number is the discharge number. For 2400's batt, you should have more than 2600 mAH charging number.
daniz24: what's your charging rate and threshold?
is smaller the charged voltage the better the cell ?
the smaller the peak voltage, the better the batt
the bigger the average discharge voltage, the better the batt the lower the IR value, the better the batt hope this help ;) |
spider : I'm using Yokomo BMS for 7.5 Amps with Yokomo-Charge profile or 5 Amps for linear charge mode...
Using a Millenium:
Delta Peak: 7mv Charge: 6amp No Trickle I don't have a Turbo 35, but could probably get one of the guys at the track to give them a cycle for me.... |
with a millenium
when reverse pulse charging the 2400s with a millenium what is the reverse pulse duration do you use?
