Old 12-23-2006, 12:44 PM   #1
TRFTIM's Avatar
Default Brushes burning down quickly
Im running a 17x2 motor and seem to be having to replace the brushes every 3 meetings is this normal and wahat can cause this?
TRFTIM is offline   Reply With Quote
Old 12-23-2006, 01:54 PM   #2
In big meetings i (and also others) replace brushes after each run, so yes, i think thats normal to replace brushes every three meetings.
Well, actually three meetings sounds quite alot for one set of brushes, but of course that depends from spring / brush / motor / timming combination used.
The faster you want your motor to go, the more often you have to service it.
Hope this helps,
Janis
JanisK is offline   Reply With Quote
Old 12-23-2006, 02:08 PM   #3
TRFTIM's Avatar
Hope this helps,
Janis
Great Help thanks
Its a Corally 17x 2 black series, springs are standard.
I get the impression that I cant adjust the timing on the motor.?
So what brushes are reccomended for performance?
Old 12-23-2006, 03:30 PM   #4
I sometimes have trouble getting 3 heats out of a set of ASC 729 quasar brushes but they are fast. ASC 737x brushes are down a little on power but wear well. With the 17 turn you are probably not looking for a lot of power so I would try the 737x or Peak/Orion enduro brushes for better motor and brush life.
plumslow is offline   Reply With Quote
Airtronics M8 NEED TO MOVE QUICKLY Schmitty R/C Items: For Sale/Trade 0 02-27-2008 03:35 PM
Need a OS cvr18-M quickly if possible Nitroflame R/C Items: Wanted to Buy 2 10-26-2007 12:24 AM
Needed Quickly for MTX/MRX 3 mtx3racer R/C Items: Wanted to Buy 1 04-28-2004 05:50 PM
why does modern motor wear so quickly? discus18 Electric On-Road 24 09-23-2003 05:14 PM
Advice quickly teamsherman Australian Racing 5 03-03-2003 12:45 AM
