Old 01-13-2006, 02:25 PM   #14866
easy e's Avatar
Trader Rating: 28 (100%+)
im scrubbin alot of speed in corners . I race on carpet, the track is small and tight , i ran a spool because that was all i had. other then running a diff what can i do to get my car stick the lines and hold corner speed?
easy e is offline   Reply With Quote
Old 01-13-2006, 02:53 PM   #14867
tried a oneway
agower is offline   Reply With Quote
Old 01-14-2006, 09:13 AM   #14868
MrUnlimited's Avatar
Which springs should I use for asphalt? White on front and blue on the rear? What is the best shock setup? Any thoughts?
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 01-14-2006, 09:25 AM   #14869
Most of the time Yellow front , blue rear with one-way. Blue-Blue or yellow-yellow with spool. Sometimes when grip is very good then White front- yellow or blue rear.
caveman is offline   Reply With Quote
Old 01-14-2006, 09:56 AM   #14870
thanks, just blew up my esc! I have another somewhere.
Old 01-14-2006, 01:02 PM   #14871
capellone24's Avatar
Hi ,
i need a good starting point to gear my SD with novak GTB 5.5 ......
thanks to all....
Cris.
capellone24 is offline   Reply With Quote
Old 01-14-2006, 08:17 PM   #14872
ChadCapece's Avatar
On medium grip asphalt w/ a spool, I like blue fronts and rears. Blue front and green rears when running on either a one-way, or low grip asphalt.
ChadCapece is offline   Reply With Quote
Old 01-15-2006, 10:11 PM   #14873
easy e's Avatar
im looking for a setup sheet that has a good carpet setup for foams on small tight carpet track .. need this BAD my yok is driving horrible awful.. undrivable i dunno whats wrong buy something is not right PLEASE help I really like yokomo but those xrays are hookin up !
Old 01-16-2006, 03:52 AM   #14874
Canuck's Avatar
Trader Rating: 25 (100%+)
For carpet, try this:
http://www.yokomo.tk/
and go with "Tosolini SD CGM 04 Carpetnats"
Canuck is offline   Reply With Quote
Old 01-16-2006, 07:43 AM   #14875
Racingbod85's Avatar
hi i've got an lcg conversion for my sd and need a setup suggestion for carpet and rubber for mainly stock but mod as well. anyone know where i can look? yok website is rubbish as is the uk distributors! nothing for lcg on either somebody help please!!
RC12L4
Novak 4.5R / 10.5R
Sanwa/Futaba/Much More
Carpetwars/Sidcup RCC/Maritime Racing/7oaksmcc
Racingbod85 is offline   Reply With Quote
Old 01-16-2006, 07:59 AM   #14876
Hi,
@Racingbod85: I don't like to copy setups because most of the time they don't seem to work. But a few things you could try:
Camber: I normally run between 1 and 2 degree. Mostly 2 because it's faster. But have a look at the tire wear. When I have only limited sets of tires I run max. 1.5 degree. That works.
Toe front: You have to look what you like better. I run 0 degree or 0.5 degree toe-out.
Toe rear: In stock I run different blocks. Sometimes it is really fast to go down to 2 degree. You'll have a lot of steering... In modified I run min. 2.5 degree.
Oil: I use only Associated oil so you have to look how you can compare this to your oil. 40wt all around with the Rayspeed pistons (1.2mmx3) works nearly everywhere. Sometimes I go a bit harder all around or only in the front. It makes the car less twitchy. I'll try this week a softer oil all around to see how it feels.
Springs: When traction is low I run in stock blue/blue, in modified blue/green. When tractions come up I switch to white/white and in modified to red/white or white/blue.
Damper positions: Nearly everywhere I run:
Front: Shock tower 3rd hole and the middle hole on the A-Arm
Rear: Shock tower outest hole and outer hole on the A-Arm
Cheers
Chris
speedy-932 is offline   Reply With Quote
Old 01-16-2006, 04:57 PM   #14877
easy e's Avatar
What changes if I put washers in between the chassis and rear suspension mount.. Im refering to step 2 in the yokomo sd cgm special manual .
Old 01-17-2006, 06:51 AM   #14878
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Default thinking caps on
right need part no. for the alloy blue gearbox`s on the lcg conversion & motor mount
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 01-17-2006, 08:03 AM   #14879
they are:SD LCG Transmission Case 3,480 SD-302L
Motor Mount for the SD LCG 2,300 SD-304L
is this for a new tub chassis? the holes for the transmisson cases are exactly the same as the regular sd.
http://www.teamyokomo.com/japan/newp...s2005_6_en.htm all of the parts on are that link, including the steering.
and this one http://www.teamyokomo.com/japan/newp...s2005_7_en.htm
on this last link, there are also lots of new and optional parts for the lcg within the differnt months of been released. http://www.teamyokomo.com/japan/newp..._eng/index.htm
gower
Old 01-17-2006, 09:31 AM   #14880
MR JOLLY's Avatar
RE;;HOLES
alloy lcg gearbox has a different footprint then the SD plastic ones ,not much but enough
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
