Old 01-10-2006, 07:15 AM   #14836
lem2's Avatar
Default My LCG
After a rebuild!
Yokomo MR-4TC SD-jt-body.jpg   Yokomo MR-4TC SD-steering-post.jpg   Yokomo MR-4TC SD-fan.jpg   Yokomo MR-4TC SD-behind.jpg
lem2 is offline   Reply With Quote
Old 01-10-2006, 09:21 AM   #14837
Originally Posted by TheRo0sTer
I just converted my SSG to the LCG and can't get my ride height lower. Right now I'm sitting at 6mm rear and 5mm front. It was recommended 4.5f and 5r for the local track but I can't get it any lower. I've already modified the spring retainers and shock ends to get lower but still NO GO. Any help would be much appreciated. Looking forward to running this new beast.
What is the length are your shocks?
What hole (upper or lower) position is the hinge pin in your C Block?
Where is the hub spacer, over or under the steering hub?
The hinge pin in the rear hub carrier should almost always be in the lower hole.
By adjusting these you should get the proper ride height.
pops is offline   Reply With Quote
Old 01-10-2006, 09:55 AM   #14838
TheRo0sTer's Avatar
Send a message via AIM to TheRo0sTer
Well right now I'm running the shocks where it was shown in the rebuild. I figured there was a way to get it lower without moving them. So are you saying go to the 2nd hole from the inside right? I'm running Associated Purple front with #1 pistons and 50wt oil, rear with whites #2s with 40wt oil. As far as the other questions Pops asked I set it up like the directions mentioned.
Man this conversion kit really brought life to the ride I already liked. The bulks are sweet and I love the steering rack!
Here's mine after the build...
I know they are all the same... Seen one seen them all, but this one is mine!
TheRo0sTer is offline   Reply With Quote
Old 01-10-2006, 10:02 AM   #14839
if your using associated springs then you need to use the rayspeed blue aluminium sprong retainers as the associated springs are longer than the yokomo ones
agower is offline   Reply With Quote
Old 01-10-2006, 10:14 AM   #14840
TheRo0sTer's Avatar
I've got modified associated cups and figured out how to modify the Yok shock ends to lower the stock cups just as far. As far as I can tell I don't think the rayspeed will get them any lower. The bottom of the retainer is already pretty much on the arm. I think moving the shock mounting positions will be the ticket.
Old 01-10-2006, 10:21 AM   #14841
The Rayspeed spring retainer will get it lower, yes the retainers will touch the lower arms when laydown the shocks, you will have to dremel some material off the arms,Yes, I saw on Masami's car, he did this mod also.
caveman is offline   Reply With Quote
Old 01-10-2006, 10:34 AM   #14842
TheRo0sTer's Avatar
Looks like I will be getting some of them later this week.
Old 01-10-2006, 01:50 PM   #14843
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
All these people with LCG's! Im still waiting for mine, a holdup with my LHS, they're building two indoor tracks I think its worth the extra wait on my LCG!
v0rtex is offline   Reply With Quote
Old 01-10-2006, 02:05 PM   #14844
LCG BITS
G'day Ro0sTer,
A good investment is to purchase the Bevel gearbox covers PN SD-302LDC which will prevent small stones from wrecking the gearboxes. These are very easy to install and come as one piece. Myself and LEM2 have them fitted on our LCG's which can be seen in the photo's.
Lem2,
Are you running Rayspeed yellow front and blue rear springs on your ride? What weight oil are you using?
Caveman,
Thanks for the info on the pistons and the arms. I was wondering if the a arms may have been graphite as the front a arms on the CGM has four holes, which aligns with the drawn up Team Yokomo LCG setup sheet. The one where they are using 500 wt oil front and 450 oil rear. This setup sheet is dated 15 Nov 05 and gives a agressive setup for the LCG.
Thankyou
Cheers
Calvin.
caltech1 is offline   Reply With Quote
Old 01-10-2006, 02:12 PM   #14845
Wink MY RIDE
Some more PICS
Old 01-10-2006, 02:14 PM   #14846
could the wishbones / aarms that they were using be the sdw arms, as i have seen quite afew setup sheets with these on, and have heard of quite afew team drivers using them as they are slighlty shorter
Old 01-10-2006, 03:50 PM   #14847
MrUnlimited's Avatar
Ok, here is mine :
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 01-10-2006, 05:03 PM   #14848
The SDW arms only have two holes molded in them.
Dan Hughes is offline   Reply With Quote
Old 01-10-2006, 05:20 PM   #14849
TheRo0sTer's Avatar
Thanks for the help. I won't be running it outside so covers won't matter. Oh yeah did I mention I picked up my conversion for $156 + shipping on eBay? I thought for sure the people would bid the price way up. I bid $201 thinking I would save $40. Wife says to me on the phone you won it for $156. I was like |-|ell yeah!
Where do I find them covers incase I do take it outside one day.
Old 01-10-2006, 06:20 PM   #14850
Thumbs up LCG DIFF COVERS
You can get them from Speedtech in the States.
Anthony, looking at your pictures of your LCG, I can see that the edges of the Cabon Fibre components are not sealed. To do this simply run a bead of superglue along the edges. This will prevent the carbon fibre asborbing water and prevent it from splitting if put into boards or other cars.
Cheers
Calvin.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
