Old 01-05-2006, 12:06 AM   #14806
SpeedTech's Avatar
Hi Guys,
Sorry I didn't catch the positive response on the thicker/stiffer chassis for the LCG. R/C Tech threads moves so fast sometimes I dont even see it and it's moved to page 2 or 3
Seems like there is a serious interest in the chassis set, I will definitely look into it. I will keep you guys posted, however, it will be a good couple of weeks before I can have some solid numbers though. We need to get the drawings done first and then input it in the program to see how many we can do per sheet of graphite before generating a cost.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 01-05-2006, 07:04 AM   #14807
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
Default Chassis
Steve, I would definitely be interested!
Have you looked into moving the batts and servo a little forward too?
fpart is offline   Reply With Quote
Old 01-05-2006, 08:18 AM   #14808
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default Thicker chassis
Steve
Count me in I've been waiting for a thick chassis to come out, Love my LCG just flexes a bit for carpet running or any high grip racing.
PM me and I'll send ya my info.
olhipster1 is offline   Reply With Quote
Old 01-05-2006, 08:53 AM   #14809
lem2's Avatar
Default Count me in
Would love to have one.
If ever, could you omit the small cut outs in the front and rear, and how about a solid top deck with the same thickness, since a thicker upper deck would require machining blue spacers at the rear.
lem2 is offline   Reply With Quote
Old 01-05-2006, 10:36 AM   #14810
My thoughts too. Maybe a better quality material too that has less flex
DOTMAN is offline   Reply With Quote
Old 01-05-2006, 11:14 AM   #14811
JayBee's Avatar
Trader Rating: 31 (100%+)
I want one too.. Oh I forgot I sold mine (DAMN!!)
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-06-2006, 08:36 AM   #14812
lem2's Avatar
Default When???
I hope they could come out with a prototype soon!!!
A stiff chassis will really be good for Modified!!!!
Will be using it here when it opens!! It's our new Indoor On-Road Track! Courtesy of a Hobbyist (JPR) it Used to be an Off Road track!
It's really BIG!!!
http://www.rctech.net/forum/attachme...hmentid=109969
Old 01-06-2006, 10:01 AM   #14813
Send a message via AIM to aoizip
jaybee... it never hurt to pick up another one.... beside your little green will say bye bye~~
Where do I sign my green baby away steve?
~Ming
aoizip is offline   Reply With Quote
Old 01-07-2006, 12:05 AM   #14814
easy e's Avatar
Trader Rating: 28 (100%+)
has anyone had problems with their 28mm foams rubbing on the hub carriers in the front?
also anyone running a spool on carpet with foams?
easy e is offline   Reply With Quote
Old 01-07-2006, 03:15 AM   #14815
Canuck's Avatar
Trader Rating: 25 (100%+)
I did and I pulled out the dremel to shave the hub carriers a bit.
Canuck is offline   Reply With Quote
Old 01-07-2006, 07:40 AM   #14816
I had problems with jaco tires. I just run Parma foams now they fit perfectly.
kmorast is offline   Reply With Quote
Old 01-07-2006, 04:31 PM   #14817
Canuck's Avatar
I am using Jaco tires and have that problem.
Old 01-07-2006, 08:43 PM   #14818
lem2's Avatar
You guys could also use the TEAM SUZUKI Lightweight Rear Hub Carrier part number TS-2106, Speedtech has them.
Its Small size will give you more clearance, but it has an ofset of 0.5 degrees, so you would have to compensate by replacing the rear suspension mount.
Old 01-07-2006, 10:30 PM   #14819
There is no problem with Jaco Foams rubbing on the rear. In order for the fronts not to rub, you can use a shim between the wheel and the hub, or use a hobby knife and remove about a mm of wheel on the inside. Parma Foams fit without any problems.
pops is offline   Reply With Quote
Old 01-08-2006, 05:23 AM   #14820
lem2's Avatar
Hi Guys!
What kind of rubber tires do you use at SoCal and what rating?
Thanks!
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
