Old 12-29-2005, 01:12 PM   #14791
Originally Posted by caltech1
G'day LEM,
Have you tried the longer steering posts that fit between the upper and lower deck, this may assist stiffening the chassis. The PNo is SD-202LPL. I am going to fit this to my LCG this week. This fits to the steering pivot pointswhere the ball bearings are. Will submit photo when completed.
Cheers
Calvin.
The longer post did absolutely nothing for my car in terms of flex. My car feels like it's made of rubber when I twist it. Makes setting tweak damn near impossible
DOTMAN is offline   Reply With Quote
Old 12-29-2005, 01:13 PM   #14792
Steve, I'm also interested in a thicker upper too. Just thought I'd throw that in
Old 12-29-2005, 07:12 PM   #14793
Oh...and just to be clear...it's the LCG chassis and upper deck...not SD
Old 12-31-2005, 04:24 AM   #14794
Hi,
I`m thinking about a thicker chassis+topdeck since I own the car.
I built a prototype of a laminated tube chassis. I never finished it because it's really difficult to laminate it and very, very expensive. Perhaps I'll start a second try this summer.
I chipped my chassis a few weeks ago (cars lying on the straightway are never good) and now I'm thinking about an alternative.
I found a guy who is able to mill CFK and said he'll try it for me. Hope it works...
Cheers
Chris
speedy-932 is offline   Reply With Quote
Old 12-31-2005, 10:51 AM   #14795
Does anybody know where I can get the LCG conversion kit?
kmorast is offline   Reply With Quote
Old 12-31-2005, 11:18 AM   #14796
precisionrc or allspeedhobbies have them
agower is offline   Reply With Quote
Old 12-31-2005, 11:39 AM   #14797
MrUnlimited's Avatar
Ask Masa @ Champ RC adviser. He is cheap comparing to others and fast delivery
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 12-31-2005, 09:36 PM   #14798
morris's Avatar
Trader Rating: 40 (100%+)
Default carpet set-up fpr cgm
hello,
i was wondering if someone could be helpfull on giving me a set-up to try for the yokomo cgm.i am using d/pink rears and d/pink/orande in the front.i basically need to know shouck oils/springs/ride height/droop.the basics.i tride using the car with a 40 weight oil in back and a 60 weight oil in the front.white rayspeed springs in the front and green yoke springs in the back.and i had purple foams all the way around.well the car was to aggresive.so i changed to the d/pinks-d/pink/orange and it was pushy.so then i tride a sway bar in the back and it helped alot.but the car was very wondery exiting a turn.and at last moment of exiting it came around with a very bad wash.i ran my droop at 1.5mm in the back and 1mm in the front.
any info on a better way to start would be greatly appreciated.
thanks for youre info guys.
matt morris
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 01-01-2006, 03:36 PM   #14799
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
Does anyone have a link to the blank LCG setup sheet, in English? I can only find blank ones in Japanese.
v0rtex is offline   Reply With Quote
Old 01-01-2006, 03:38 PM   #14800
yes, here you go http://www.cmldistribution.co.uk/pro.../lcg_blank.pdf
Old 01-01-2006, 03:53 PM   #14801
Thanks, didnt think to look on the CML site
Old 01-01-2006, 04:54 PM   #14802
I just found this great deal on a yokomo SD spool check it out!
http://cgi.ebay.com/Yokomo-SD-SSG-CG...QQcmdZViewItem
Old 01-01-2006, 11:28 PM   #14803
easy e's Avatar
Trader Rating: 28 (100%+)
What pinion should I start with for a monster stock , with stock 48p spur ?
small tight carpet foams
easy e is offline   Reply With Quote
Old 01-01-2006, 11:33 PM   #14804
Check the setup sheets you received with the box. Start from there and you'll always able to gear up or down. Good luck.
Old 01-02-2006, 08:30 AM   #14805
lem2's Avatar
Default Question
Happy New Year Guys.....
May I ask what tracks are there, both carpet and asphalt between LA and Chula Vista? I only know of the Tamiya Track and SoCal. Are there other racetracks out there, even parking lot races on weekends?
I need to know which place to stay to be stratgically in between these tracks....
Any reply would be greatly appreciated!
Thank You Very MUch
lem2 is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
