Yokomo MR-4TC SD
Old 11-07-2005, 01:44 PM
  #14731
deffinetley the lcg,
i have one on ebay you can buy http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEBI%3AIT&rd=1
agower is offline
Old 11-07-2005, 02:26 PM
  #14732
rc_bam226's Avatar
Originally Posted by xrcbuggy
Guys need some help here please; Should I buy MR-4TC SD SSG (the original one) for $270.00 it is avalible in US. or it is too out dated? Or should I go for LCG (it is avalible only from overseas)?
Just go get the LCG for about $420. When you get the SSD for 270 and get the conversion for like 240, you spent alot already. Steve, at www.speedtechrc.com sells the LCG as a kit as well as the conversion.
rc_bam226 is offline
Old 11-07-2005, 07:13 PM
  #14733
rough512's Avatar
Originally Posted by blindwolf
Yeah, don't drive on unprepared tracks or lots....Also, I have had no problems with the gear covers. Maybe your amigo did not install them correctly? Bottom line is that nothing works as advertised, period!
Yes, it's installed correctly. Our local track is decently clean, it's when the car get's hit and flies outside the barriers that trouble starts. Ours is a converted tennis court, and there is a sandy court nearby.
I've spent many hours staring at the gear box thinking of a way of sealing it better and gave up. There simply is no room behind the diff gear for a shield.
Then I came up with a very neat solution, I swapped the LCG for a 415. Problem Eliminated. No more worrying of stripped gears on collisions or of pebbles getting into the drivetrain.
rough512 is offline
Old 11-07-2005, 07:20 PM
  #14734
ChadCapece's Avatar
rough, hate to break the bad news, but Yokomo released gear covers about 3 weeks ago. They can be found here:
http://www.speedtechrc.com/store/ebp...?catmainid=419
ChadCapece is offline
Old 11-07-2005, 07:44 PM
  #14735
rough512's Avatar
Chad, yes my buddy has these gear covers. The shield does not go behind the diff gear. That's where the pebbles are getting in.
I still think the LCG is a very good car, my buddy's giving me a hard time with his LCG. I'm just not comfortable with the open diff case.
rough512 is offline
Old 11-08-2005, 08:54 PM
  #14736
Piyo Piyo's Avatar
If I alter the roll center by putting 1mm shims on every suspension mounts on the car (F & R) so the suspension are up for 1mm, what is the driving characteristics I got compared to susp mounts without 1mm shims?
Thanks in advance
Piyo Piyo is offline
Old 11-08-2005, 11:00 PM
  #14737
JayBee's Avatar
Trader Rating: 31 (100%+)
Try it out for yourself first
JayBee is offline
Old 11-10-2005, 10:34 AM
  #14738
capellone24's Avatar
hi guys
i'm looking for SDW setup sheet (asphalt track medium grip..) yokomousa has removed both masami's and blank sheets
if someone could mail to me :
[email protected] (remove nospaam...)
thanks to all....
capellone24 is offline
Old 11-11-2005, 08:11 PM
  #14739
rezalb8891's Avatar
ssg sd for sale anyone barely ever drove well maintained comes with worlds driveshaft front one-way extra arms and castor blocks
http://www.rctech.net/forum/showthread.php?t=89268
make offers
rezalb8891 is offline
Old 11-11-2005, 08:25 PM
  #14740
Piyo Piyo's Avatar
Originally Posted by capellone24
hi guys
thanks to all....
Here you are... .
File Type: pdf
Old 11-12-2005, 02:35 AM
  #14741
Thanks very much Piyo!!!
Old 11-20-2005, 08:50 AM
  #14742
lem2's Avatar
Default What's Up
I just sold my FT-TC4 after 2 races!!
I'm back where I belong!!!!
Any thing new with the LCG???
Has anyone tried the One Way Shaft? How was it?
Lem
lem2 is offline
Old 11-20-2005, 09:38 AM
  #14743
Hi guys....there is any way to get the white gears?? i've heared that the white material last longer than graphite or plastic .....
Thanks!
Old 11-20-2005, 09:42 AM
  #14744
lem2: if you got to www.yokomo.co.jp and then new procuts eng up the top then you can see hat has come out in the last few months, things like, gear covers, differnt steering plate with akerman locations, longer steering posts that attach top and bottom decks. nothing much else i dont think. i was thinking about getting the oneway centre shaft aswell. where were you plannig on getting yours from??
capellone24: i dont think you can get the white gears anymore, they were just what was out right at the start of the sds life. same part number as the black plastic ones. just different colour....
hope this helps you both
gower
agower is offline
Old 11-20-2005, 10:25 AM
  #14745
Thanks!
The white plastic is the same strength as the back plastic, only they added black die...
pops is offline
