Yokomo MR-4TC SD
Old 10-16-2005, 08:42 PM
  #14686
Piyo Piyo's Avatar
Originally Posted by spanish armada
can anyone steer me in the direction of replacement of my universal driveshafts both front and rear on my SDW....i.e. best prices,brands,etc....anyadvice grateful...thanks
You can replace it with Yokomo SD universals, sold as a set or separately.
Other option, try MIP universals for Yok. They also work great. Rayspeed also sell this MIPs.
Piyo Piyo is offline
Old 10-17-2005, 01:23 AM
  #14687
beer_drinker's Avatar
Originally Posted by MIKA
I need some advises on setting up the LCG. I have massive understeer problem. Im not sure I have to blame it on the stock steering ackermen. I must say my CGM can steer much better.
Before you check the setup, check your radio settings. If the steering endpoints or the dual rate was set at a low value that would definately cause understeer.
beer_drinker is offline
Old 10-17-2005, 03:02 AM
  #14688
sosidge's Avatar
Originally Posted by ChadCapece
Dialed also works I'll try to set my cars up to have oversteer w/o plowing the front tires. Then I don't have to turn the wheel all the way to get around tight turns. I run just over 100% Dual Rates.
Also, I have 140% braking in the esc and radio. Enough to lock up the tires at full speed. It helps alot when someone wrecks infront of you, or you're racing close with someone.
You have a strange way of setting up your radio... it's like in Spinal Tap... "but our amps go to 11"
sosidge is offline
Old 10-17-2005, 09:30 AM
  #14689
hi,
do any of you know where i can get the stiffener posts for the LCG, optional steering plate, and gear covers for the LCG from?
that ship internationaly and can order over website? oh yeah and in english?
also thats not rainbow10
thanks alot
agower is offline
Old 10-17-2005, 05:00 PM
  #14690
Regional Moderator
FroBoy's Avatar
Default Roll Out!
Does anyone know what the internal gear ratio for the CGM, SSG, LCG is? oR DOES ANY one have a roll out chart already figured up on this car?
FroBoy is offline
Old 10-17-2005, 08:15 PM
  #14691
Piyo Piyo's Avatar
Internal Ratio for SD : 2.35
Old 10-18-2005, 10:47 AM
  #14692
SpeedTech's Avatar
Hi Guys,
We just updated our website with a lot of new products for the SD LCG:
Yokomo Hardened Factory Front Universal Driveshaft for SD/BD
Yokomo Hardened Factory Rear universal drive shafts for SD/BD
Yokomo Upgrade aluminum steering bellcrank for SD LCG with different ackerman positions
Yokomo SD LCG Long Steering post upgrade
New Yokomo MR-4TCSD LCG and Worlds Kit diff covers (agower, I think this is what you're looking for )
Plus a lot more new products all available on this page SD LCG and Worlds kit hop-ups
I've also attached some new pictures of these products. Enjoy!
Steve Wang
Attached Thumbnails Yokomo MR-4TC SD-sd-302ldc.jpg   Yokomo MR-4TC SD-sd-010fh.jpg   Yokomo MR-4TC SD-sd-644a.jpg   Yokomo MR-4TC SD-ys-1sss-7.jpg
SpeedTech is offline
Old 10-18-2005, 03:52 PM
  #14693
nice one steve, i see the lnog steering posts are out of stock already any idea when the nest lot wil be in
thanks
agower is offline
Old 10-18-2005, 05:09 PM
  #14694
Yeah, they didn't last very long did they
DOTMAN is offline
Old 10-18-2005, 05:17 PM
  #14695
SpeedTech's Avatar
Hi Guys,
I'm very sorry about that. I didn't realize what they were until I saw them in person, should have definitely order more. Should have another shipment towards the end of the month/early next month. Again, my apologies.
Steve Wang
Old 10-18-2005, 11:15 PM
  #14696
SpeedTech's Avatar
R/C Tech Special (just for you guys )
We have 1 specially packaged SD LCG Kit with a wonderful free gift inside each one (gift worth over $60 in retail value) for the same price of $419.99 Just place an order on our website MR-4TCSD LCG
And I promise the gift will be something all electric racers can use
Steve Wang
Old 10-19-2005, 05:15 AM
  #14697
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default YOK SHOCKS
It appears the Yokomo is selling there YS-1SSS-7 Low Friction Shocks that come on there SD and BD touring cars separately from the kit. They will retail for $30 a set of 4 with bladders included according to Xtreme RC.
I just wanted to ask the YOKOMO Drivers about the quality of the shocks and would you compare them to the Tamiya TRF shocks?
Thanks,
E
RED-LINE M03 is offline
Old 10-19-2005, 05:18 AM
  #14698
well put it this way, have you ever seen a yokomo running trf shocks? i sure havent and i dont run trf shocks on mine, however on other cars eg xray, schumachers the run trf shocks. the yokomo shocks are just as good as the trfs in my opinion
agower is offline
Old 10-19-2005, 05:20 AM
  #14699
Matt Howard's Avatar
Matt Howard is offline
Old 10-19-2005, 08:37 AM
  #14700
Regional Moderator
daniz24's Avatar
Good quote. Even Maezumi and David Jun are spotted using older Yokomo shock (with non-bladder system) on their 414M before...
daniz24 is offline
