Old 09-30-2005, 05:17 AM   #14626
tight enough so if you hold the spur gear and one wheel that it is very hard to impossible to turn the other wheel, if you ahve diffs fornt and rear then make sure the front is tighter or equal to the rear diff, but never the rear diff tighter than front.
agower is offline   Reply With Quote
Old 09-30-2005, 08:29 AM   #14627
Talking
cool, that's how I'll set it !!
tharv is offline   Reply With Quote
Old 10-03-2005, 03:00 PM   #14628
Hi,
the SD-415G steering knuckles come with the kit. They are marked with a "1". And then there are the "Non trailing steering blocks" which are marked with a "0". I used the Team Suzuki knuckles and now I will switch to the graphite ones. Which are equal to the Suzuki knuckles? And what will happen when I use the "0" knuckles?
Cheers
Chris
speedy-932 is offline   Reply With Quote
Old 10-03-2005, 03:40 PM   #14629
Originally Posted by speedy-932
Hi,
Cheers
Chris
The Suzuki knuckles are .05 deg
You should see the car be a little more twichy with 0 deg compaired to the 1 deg knuckles.
pops is offline   Reply With Quote
Old 10-04-2005, 01:23 AM   #14630
Thumbs up DIFF COVERS FOR LCG
Info for those that have the LCG. I received my Diff covers today and have discovered that you only need to order one packet. There are two diff covers in the packet. Don't do as I did and order two packets, as they are not required.
I have not fitted them as yet. I also received the steering arm long spacer set, which I will retro fit later. these items were supplied by my LHS Hobby Habit for those in Australia. Thank you to them for there efficient service. I will take a picture and post when fitted.
caltech1 is offline   Reply With Quote
Old 10-04-2005, 07:21 AM   #14631
Regional Moderator
daniz24's Avatar
This is my LCG with diff cover pics, yes they're come in 1 pair per package. It also supposed to fit to the SDW, but haven't try it yet.
daniz24 is offline   Reply With Quote
Old 10-04-2005, 06:14 PM   #14632
JayBee's Avatar
Trader Rating: 31 (100%+)
Any word on Yokomo releasing the LCG conversion as a full kit yet?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 10-04-2005, 06:20 PM   #14633
Matt Howard's Avatar
I just emailed Yokomo USA this very question, hopefully I'll hear something back by tomorrow
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-04-2005, 06:22 PM   #14634
JayBee's Avatar
Cool, thanks Matt. Keep us posted
Old 10-04-2005, 08:19 PM   #14635
Piyo Piyo's Avatar
For SDW, you need to scribe off some part of the diff cover at the area which cover the small bevel gear. The diff cover sit 90% at the bulkhead but you need removable glue (like UHU or silicone glue) to make sure it doesn't move. Will post my picture of it later.
VIOLA ARIELLE & FLOREN ISABELLE
Piyo Piyo is offline   Reply With Quote
Old 10-04-2005, 11:51 PM   #14636
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default Need Help
I'm having trouble with the steering cranks.
They either keep getting loose during a race or I have to overtighten to keep it from happening which in turn makes the steering to slow. Is there solution or fix for this?
And who is selling the diff covers?
olhipster1 is offline   Reply With Quote
Old 10-05-2005, 02:24 AM   #14637
Piyo Piyo's Avatar
Why don't u use locktide for the cranks (if you mean LCG)?
The diff covers are original from Yokomo.
Old 10-05-2005, 02:34 AM   #14638
Regional Moderator
daniz24's Avatar
What do you mean? It's already out for at least a month. Here's my LCG kit box
Old 10-05-2005, 06:35 AM   #14639
Where did you purchase it though? I'm going to check to today but I'm pretty sure Yokomo USA only brought in the conversion kits and not the full kits.
RCTech #361
Old 10-05-2005, 07:15 AM   #14640
Aries326's Avatar
Trader Rating: 19 (100%+)
Default Steering Hub Carrier
Hey, guys, I got a Yokomo DP chassis on a trade for a Tamiya M04L and I bought a CGM chassis and parts off of olhipster1 from rctech. I'm trying to convert it to the CGM but it seems the previous owner of this Yokomo DP had some missing parts. I'm looking to find out if I can buy some Steering Hub Carriers King Pin Collars seperately or if it only comes included with the Steering Block. Any help is appreciated. Thanks!
Aries326 is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
