Old 07-27-2005, 10:33 PM   #14281
ChadCapece's Avatar
Alright, I finally got around to sealing the edges of the chassis and shocktowers.
I've been testing with the Speedtech steel spool, and with stock, it's junk. The acceleration was slower with the steel spool than a plastic one. I noticed just an overall sluggish feel. Now with 19turn and mod, steel spool is the only way to go, as long as you don't hit stuff. Steel spool breaks the cvd's and the plastic one just makes them tweak.
ChadCapece is offline   Reply With Quote
Old 07-27-2005, 10:47 PM   #14282
blindwolf's Avatar
Default Hiroshi_LCG_setup
Found this on the Japanese site but need a translation. Anyone here able to translate this setup sheet? Appreciate any and all help.
blindwolf is offline   Reply With Quote
Old 07-28-2005, 07:50 PM   #14283
Switch Blade's Avatar
Send a message via AIM to Switch Blade
Hey, ive been out of touring car racing for quite some time and finally decided to pic up an SD. The car seems to go together pretty straight forward, but i am having trouble with a few this. I need a few recommendations for a few things: Droop, and shock oil. The manual doesnt mention what to start with(i am running stock rubber)
thanks
College
Switch Blade is offline   Reply With Quote
Old 07-28-2005, 08:30 PM   #14284
ChadCapece's Avatar
thanks
asphalt or carpet? With asphalt, I like to start with 40wt front and rear oil and #3 droop on a Yokomo gauge.
Old 07-28-2005, 08:45 PM   #14285
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
I can help... what sections are you looking to find out about..???I.E. springs body type of track ect ect..
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 07-29-2005, 07:46 AM   #14286
Ah yes I forgot to say i am racing on carpet. Should I use the same amount of droop or is it better to start at a different place
College
Old 07-29-2005, 08:49 AM   #14287
ChadCapece's Avatar
3 droop will give more roll than a higher number. I couldn't tell you a good droop number for rubber/carpet
Old 07-29-2005, 08:52 AM   #14288
You should be able to lift the chassis 2mm in the front before the wheels come off the board and 3 to 4mm of lift in the rear.
pops is offline   Reply With Quote
Old 07-30-2005, 09:06 AM   #14289
Hi,
I have news about the alumium outdrives and spools. I found a guy who is able to make them on a CNC for a good price.
The price for the outdrives will be around 35$, perhaps less.
And the spools will cost 30$.
The prices seem a bit high but I think the parts should last nearly forever. I designed both parts to fit with Xray blades.
If someone is interested drop me a PM.
Cheers
Chris
speedy-932 is offline   Reply With Quote
Old 07-30-2005, 01:02 PM   #14290
ChadCapece's Avatar
I've got my LCG almost perfect. Still waiting on a few more hopups, but here's what I've already done:
Rayspeed spring retainers, orings, bladders.
Speedtech spool
P-dub bumper
Precision bearings where needed
Reedy motor heatsink-fan
Ti hingepin screws
Ti motor screws
LCG conversion
HPI studs
open top ball cups
Al. input shafts
Worlds/custom upgrade kit for quantum
PT
ect...
I've got the car to weight right around 1510 grams.
here's some pics
Yokomo MR-4TC SD-rc-items-050.jpg   Yokomo MR-4TC SD-rc-items-051.jpg   Yokomo MR-4TC SD-rc-items-052.jpg   Yokomo MR-4TC SD-rc-items-055.jpg   Yokomo MR-4TC SD-rc-items-062.jpg
Old 07-30-2005, 01:04 PM   #14291
ChadCapece's Avatar
more
Yokomo MR-4TC SD-rc-items-059.jpg   Yokomo MR-4TC SD-rc-items-065.jpg   Yokomo MR-4TC SD-rc-items-066.jpg   Yokomo MR-4TC SD-rc-items-067.jpg   Yokomo MR-4TC SD-rc-items-068.jpg
Old 07-30-2005, 01:50 PM   #14292
NIC
speedy-932,
Im VERY interested ! Perhaps the MOST interested of all living creatures !
I will PM you tomorrow.
NIC
NIC is offline   Reply With Quote
Old 07-30-2005, 03:02 PM   #14293
ChadCapece's Avatar
glued in battery grid
dremeled arms for rayspeed cups
dremeled arms for full travel with C-hubs
dremeled p-dub bumper to save weight and allow full wheel turn
Old 07-30-2005, 03:10 PM   #14294
edit
agower is offline   Reply With Quote
Old 07-30-2005, 03:20 PM   #14295
ChadCapece's Avatar
Originally Posted by agower
edit
How much does your LCG weigh? I saw that you had Al. blocks and carriers.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
