Old 06-27-2005, 04:44 PM   #14011
racer's Avatar
has anyone tried placing the LCG on an SD chassis?
the steerings posts can be changed to the raypseed version. not sure if the upper deck and motormount has to be changed as well. there would be no need for a custom 3mm chassis.
racer is offline   Reply With Quote
Old 06-27-2005, 05:59 PM   #14012
hurley081182's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to hurley081182 Send a message via Yahoo to hurley081182
hey guys check out what i've done with my rayspeed kit . i dont have everything done that i want to do. i still have the rpm ball cups to cut down and add and a few aluminum parts that i am waiting for in the mail. what u guys think of it so far? anyone have any more ideas for what i should do to it?
Old School Stampede=FUN
hurley081182 is offline   Reply With Quote
Old 06-27-2005, 06:06 PM   #14013
rc_bam226's Avatar
You'll probably need spacers to raise the upper deck to the same height as the steering posts. Since the LCG spec states that the height is lower than the SD, and the SDW. A close alternative would be to use the SDW steering posts which are lower by almost 3mm compared to the original SD posts.
rc_bam226 is offline   Reply With Quote
Old 06-27-2005, 07:45 PM   #14014
rough512's Avatar
I have tried replacing the LCG lower deck with an SSG lower deck. All holes line up except for the LCG steering post and Battery posts, I had to drill the SSG chassis for these.
I was halfway through the build when I noticed that the LCG with SSG plate is LOT HEAVIER!!!!. So, I swapped the LCG chassis back. I'm going to try to lighten the LCG as much as possible and reserve it for BIG RACE duty. My current SD SSG which is still running great will be for practice and club races.
rough512 is offline   Reply With Quote
Old 06-27-2005, 08:08 PM   #14015
rc-zombies's Avatar
be careful where you place all those alumunum screws... especially in high stress areas like the toe blocks.
Old 06-27-2005, 08:35 PM   #14016
rough512's Avatar
You might also have to apply CA on the counter sunk holes on the bottom deck. Carbon Fiber has tendency of "grabbing" the screws. CA helps smoothen the sandpaper-like surface of the bottom screwholes. Also, I avoid using non-steel screws for aluminum bulkheads and hingepin blocks.
Old 06-27-2005, 10:41 PM   #14017
Yes it's pretty, but can be a real bitch when you try to remove the screws. Ti screws are not the easiest, but aluminum can be a nightmare.
pops is offline   Reply With Quote
Old 06-28-2005, 02:04 AM   #14018
that to me doesnt look like the lcg, notice that the camber links attach to a carbon piece and not to the ulkhead directly, and the whole bulkhead looks differnt aswel. also the shock towers look slightly different.
could be wrong though.
agower is offline   Reply With Quote
Old 06-28-2005, 08:40 AM   #14019
racer's Avatar
on Yokomo Japan, the LCG will be sold as a whole kit. 49,980YEN
Old 06-28-2005, 09:53 AM   #14020
Send a message via AIM to aoizip
49,980YEN .... that is another 410 greens for our skinny wallet!!
BUT I got my LCG conversion already.....
anyway.... broke 2 of my turnbuckle today at parking lot bashing with my brother~
Just wondering... which kind of turnbuckle are you guys using?
lunsford ti turnbuckle? standard yok one? Associated TC3 one?
as i'm in the market for the Ti turnbuckle. but is it worth it of bleeding out
our hard earn greens for them?
oh yeah... can i also use TC3's shock spring with the rayspeed cup?
thanks guys...
~Ming
still running my rayspeed.... when am i going to have time to build my BD and LCG and runs them
aoizip is offline   Reply With Quote
Old 06-28-2005, 10:27 AM   #14021
whats the difference between alumimum, ti, and steel(or whatever screws that come with the car) screws?
Old 06-28-2005, 10:31 AM   #14022
rtypec's Avatar
You should never put CA in the countersunk screw holes. They are typically machined to closely match the shape of the screw that goes into them. With a build up of CA, the screw may stick out and not be flush or below flush. A chassis with screws sticking out of the bottom will not lay flat on a setup board.
rtypec is offline   Reply With Quote
Old 06-28-2005, 10:31 AM   #14023
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
strengthness & weight:
steel > ti > aluminum
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 06-28-2005, 11:30 AM   #14024
Aluminum is very light and soft.
Ti is light but not as soft as Aluminum.
Steel is steel, it is harder than the rest.
Some people have said that aluminum screws going into aluminum bulk heads will begin to react to each other, being of the same metal, and begin to corode. I am not so sure of that. But it is sometimes a good idea to use locktite on metal to metal, and the screws being made of Aluminum are very soft. They can get too tight and then you can't get them out without stripping the heads. Then you have a problem, it's dremel time!
Old 06-28-2005, 11:37 AM   #14025
rc-zombies's Avatar
it's basically when using Ti screws into aluminum. they will weld to each other if not properly treated....go to a Bicycle store and pick up some Ti-Prep. apply it to the screw threads....
I just use regular Diff Grease on all the screws...whether it's Ti or Steel. makes it alot easier to install and remove.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
