Old 06-14-2005, 08:30 AM   #13906
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Originally Posted by JayBee
Thanx Shook, that's just the info I was looking for. You're becoming a regular source for info around here. Are you trying to take over Matt H. and pops spots? I haven't put my LCG together yet but maybe that's because I'm sorta in that I HATE putting used pieces on a new kit/conversion. Go figure . So I'm just compiling a list of parts needed to get started on this thing. I think I have 95% of everything, just double checking. I did race my BD yesterday though -JB
Well dish how did you do.
And no I do not want Matt H's or pops spot...Just only answering what I come across and have already asked Matt and pops...LOL just helping them out by answering the repeat questions.
I understand about using used parts but I have enough spares to almost rebuild my Rayspeed,I think a set of CVDs for the front and a couple diff bearings and its done, thought about selling it or just keep it to run down in Mexico when the church goes down for missions trips and I can entertain the orphans kids.
-Stephen <><
Oh yea the LCG is way under weight...I am going to weight it again and make the exact wieght calibrations...will let you all know where and how much weight.
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 06-14-2005, 10:15 PM   #13907
Default Carpet
Guys a CArpet question for you all.
Running my SDW on carpet, with some success!!
The question i have relates to wat some guys ahve said is 'Oil" coning out of the carpet during the meeting.
At the beginning of the meeting, the car is very good, possibly a little pushy, but as th night goes on, the rear becomes progreessivly looser. Some have said that its "oil" coming out of the carpet, as it is still reasonably new, and others are experiencing the same thing. The ryres do feel a little slimey by the end of the night, but the do feel tacky before going slick (Using a med hard set up, rayspeed red allround, and 40shore foam fr and rear)
has any one else heard of this, and what can i do to keep the rears from going off?
TRied going harder in front, and this didnt help much either
Xray T2 09 (still) - LRP - MuchMore - Futaba 3PK (still)
Bluey_74 is offline   Reply With Quote
Old 06-14-2005, 10:39 PM   #13908
Matt Howard's Avatar
I would try a softer rear tire to try and keep your rear end planted when the track get's slick.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 06-14-2005, 10:52 PM   #13909
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
Ill just add to what Bluey_74 just said (I race there too) we dont allow any traction compounds on the cars at all.
v0rtex is offline   Reply With Quote
Old 06-15-2005, 02:14 AM   #13910
Guys, sorry if this sounds off topic but does your ESCs feel warm after a run? I run modified and a GTX and I dont know how hot should the ESC be so I dont know if my GTX is having problems or not...
When I m using a 7Turn its really hot, touchable but very hot, would 12G wire help to lower the heat? I m already direct soldering everything so...
BTW, my GTX starts to feel a little warm even when I run a motor with no load, is it ok?
Thanks!
Tbevofreak is offline   Reply With Quote
Old 06-15-2005, 03:54 AM   #13911
Unhappy BD OR LCG
I presently run a CGM which I'm thinking of upgrading with the LCG conversion. However I'm unsure whether it would be better to purchase a BD and use the CGM for spares. I have a second CGM that I can also Xmas tree. Is the BD the better choice? I currently run on 540 PRO and am going to Stock 27 turn.
caltech1 is offline   Reply With Quote
Old 06-15-2005, 04:35 AM   #13912
Thanks!
Yes it is normal for your esc to get hot when running, especially with a 7turn. Have you seen the pics of the pro's cars with the fans blowing directly on the heatsinks? As long as it's not shutting off and going into thermal shutdown your fine.
RCTech #361
Old 06-15-2005, 04:37 AM   #13913
Honestly you can't go wrong with either car, but for stricktly running stock or 540 then I would go with the LCG since the shaft drive will probably be a slight benefit over the belt drive.
RCTech #361
Old 06-15-2005, 08:59 AM   #13914
You are so right about the fan, not only for the speedo but for the motor. We did not run a fan at the Speedworld Cup, and the Quantum 2 was fine as far as I could tell, but the motor got so hot that the soilder on the + brush melted and the brush came off. The + spring actually melted to remove all tension from the spring as well. I think if we had a fan on the motor, we would have done much better. This happened on the 1st and 3rd A main at about 4 minutes into the race. I am working on a fan mount for the BD this week.
pops is offline   Reply With Quote
Old 06-15-2005, 09:09 AM   #13915
tell the kid to lay off the throttle a little bit, LOL
RCTech #361
Old 06-15-2005, 09:53 AM   #13916
ChadCapece's Avatar
I'm running an open 19turn class. That means that I can build a KC handwound motor at 40*timing . Only problem is that our track is very technical then has back2back braking zones, then a long 200ft straight. So my motors get scorching hot!!!! I'm using the Reedy fan/heatsink device. I've only used it once, but it made a noticable difference on the endbell temp. I've also got the RIDE cool air scoop to channel air over the can. My non-XXX brushes look just like yours after one run, but some 767's looked fine after the fan was used and I put two runs on them.
ChadCapece is offline   Reply With Quote
Old 06-15-2005, 10:18 AM   #13917
coastaltony's Avatar
FOR SALE
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 06-15-2005, 10:21 AM   #13918
ChadCapece's Avatar
how much for 1
Old 06-15-2005, 10:38 AM   #13919
$18.00 mailed to your door.
Old 06-15-2005, 11:07 AM   #13920
Yokomo has their version of the new VFS-1 Competition esc coming out as well.
RCTech #361
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
