Old 06-06-2005, 09:11 PM   #13801
Kyew's Avatar
Originally Posted by ali_g
guys any problems with stones destroying the gears?
so you getting a LCG?
all we have to decide is what to do with the time that is given to us.......
Kyew is offline   Reply With Quote
Old 06-06-2005, 09:24 PM   #13802
ChadCapece's Avatar
When you rebuild your diff:
1. take off center driveshaft
2. attach stock motor
3. hold one tire in your hand
4. run the motor at low speed for two minutes
5. hold other tire and run motor for another two minutes
6. check for slippage
7. tighten until no slip
this should seat the d-rings on the balls. Then when you tighten it up, the gear will spin true
ChadCapece is offline   Reply With Quote
Old 06-06-2005, 10:55 PM   #13803
the little click sound and slight binding is because you still have a little flashing left on your diff outdrives. also causes wobbling. when the flashing comes around it is hitting the bevel gear.
Turtlemaster is offline   Reply With Quote
Old 06-06-2005, 11:31 PM   #13804
I'm using the standard shims and graphite gears.
Cheers
Chris
speedy-932 is offline   Reply With Quote
Old 06-07-2005, 12:16 AM   #13805
ali_g's Avatar
hopefully yokomo comes out with a plastic cover for the gearbox
ali_g is offline   Reply With Quote
Old 06-07-2005, 01:28 AM   #13806
thank you all of you, will have to try all of your suggestions.
agower is offline   Reply With Quote
Old 06-07-2005, 07:37 AM   #13807
Regional Moderator
daniz24's Avatar
I second that
daniz24 is offline   Reply With Quote
Old 06-07-2005, 07:43 AM   #13808
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Originally Posted by daniz24
I second that
Since we are all wanting some...Let me ask Steve to see if he can get Yokomo or at least maybe an aftermarket manufacter to make some...
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 06-07-2005, 11:37 AM   #13809
i third it
Old 06-07-2005, 12:11 PM   #13810
blindwolf's Avatar
Originally Posted by Mr. Shookie
Well All,
I just got home and un wound from this weekends Series race with teh New LCG.......
Here is what I found.....
THIS CAR ROCKS
I had a couple problems until a freindly neighbor hood Yok Guy Glenn G...Hey Glenn if you read this Thanks a bunch.
I found you have to add the 1-1.5mm spacers under the blocks (which helped with the ride hieght issue)...I was running without them and it seemed rough. With that and a good diff shimming everything was right as rain until what everyone who had conserns about open diffs happened to me....Yup a rock got in there....The second qualifier and my car was all over...I only managed to make the C main....But thanks to GOD and my LCG re-dialed (pun fulley intended) I bumped to the B Main and came in second only because I couldn't make it through all the lap traffic fast enough...I had the Motor (thanks go out to EA) and battery (thanks to Promatch) and if I hade two more laps I probably still wouldn't have cought up...LOL But hey I didn't have another battery ready for the A main anyway so it was all good So got the First place in the B-Main cause the real winner bumped...Story of my life....B-Main Master...LOL
Only suggestions for you guys is to go with the 2.5 rear block....helped a bunch. Get the drive train as free as possible without slop and the LCG can win big....
I think I am totaly thrilled with this car. Hope everyone else loves it too.
I am going to either make some or see if Steve (speedtech) can get more of the Lexan covers for the diff cases (although they are for the EVO IV) I can make them work for the LCG.
Stephen <><
hi shookie,
I tried the spacers under the suspension mounts to no avail. I'm at 6.5(front) and 7.5(rear) in height. When i lift the front end and wiggle the spring it is sloppy, same with the rear.This sloppy wobble is not supposed to be there correct? I'm so frustrated! Someone please have one of the Yokomo guys post pic with setup ex; Dampers(long or short body) yadda,yadda. Just something visual and written for me to grasp. I'm about 2 throw in the towel.
blindwolf is offline   Reply With Quote
Old 06-07-2005, 12:13 PM   #13811
Use short bodies and ends and the length by the sounds of things should be about 60mm.
Dan Hughes is offline   Reply With Quote
Old 06-07-2005, 12:18 PM   #13812
blindwolf's Avatar
Default Doh!
Hey Dan,
My dampers are at 60mm with short body(?) and ends(screwed 2 no thread left). Oh well...
Old 06-07-2005, 12:22 PM   #13813
Post a pic.
Old 06-07-2005, 12:26 PM   #13814
i really cant think of anything else that it could be, what springs are you using and are you using the blue alloy rayspeed spring retainers that you HAVE to use? are you using the lower hole on each on all hubs?
ill post a pic of my car to show you at the rear becuase its easier to see.
Old 06-07-2005, 12:29 PM   #13815
heres the pic, cant see much because camera is flat so cant take any more.
also go on the link on my signature for some more pictures that MAY help.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
