Old 06-06-2005, 01:17 AM   #13786
Now thats should be hard to find!
Where did you find that pic?
Its the one way shaft, right? Should it increase of power steering with a one way?
Is is available?
Yeah I know thats a lot of questions...sorry
Tbevofreak is offline   Reply With Quote
Old 06-06-2005, 01:37 AM   #13787
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Everytime I have run double 1 ways on belt cars it seems to take a little aggressiveness out of the steering. I dont see why it would be any different on a shaft car, but it is a good tuning aid if you want to smooth out the steering.
Old 06-06-2005, 02:49 AM   #13788
What about running the one way shaft with a spool? Could it add the advantages of both?
Doesn anyone know if this is available somewhere on the net?
BTW, Thanks Randy!
Old 06-06-2005, 03:51 AM   #13789
racer's Avatar
Originally Posted by Mr. Shookie
I found you have to add the 1-1.5mm spacers under the blocks (which helped with the ride hieght issue)
did you place spacers under all the suspension mounts?
Thanks in advance!
racer is offline   Reply With Quote
Old 06-06-2005, 05:12 AM   #13790
I tested the LCG in mod this weekend on asphalt. The car handled good but the driver didn't worked. 1 pack for training, 3 heats and 3 finals... That's too less for me for completely new track... I ended 7th overall...
In 3 weeks another race take place at this track and I will try it again...
Cheers
Chris
speedy-932 is offline   Reply With Quote
Old 06-06-2005, 08:39 AM   #13791
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Thanks in advance!
Nope just rear/rear for now.
I am going to run some more test next week. I need a break and I need to start preparing my BD for the Ko Propo Grand Prix in few weeks. The LCG has some testign yet to be completed but so far it has done better than I could have expected.
Truly a world class car.
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 06-06-2005, 09:55 AM   #13792
ali_g's Avatar
guys any problems with stones destroying the gears?
ali_g is offline   Reply With Quote
Old 06-06-2005, 10:07 AM   #13793
Not so much desroying. But yes I had a rock get in the rear diff and caused some trouble, but I am either makign my own covers (out of lexan) or seeing if I can Modify this to work.
http://www.speedtechrc.com/store/ebp...id=418&id=4633
We willhave to wait and see.
One thing though the track had loose pebbels so I was askign for trouble. No not really. it was a fluke thing and I had it fixed in about 3 minutes. Bevel gear is plastic and rign gear is grafite, the plastic and cheap bevel gear takes the beating and leaves the ring gear in tacked. I ahve like five extra bevels anyway so really it isn't that common of a thing to happen, especially when running a very well groomed track. The one I was running on is do for a re-asphalting...Hopefully soon.
Stephen <><
Old 06-06-2005, 10:52 AM   #13794
hi mr-shookie and speedy-932
how have you shimmed the diffs and input shafts on your lcg? im having trouble trying to get it free with it being quiet at the same time!
any ideas?
thanks
agower is offline   Reply With Quote
Old 06-06-2005, 12:11 PM   #13795
hurley081182's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to hurley081182 Send a message via Yahoo to hurley081182
so is the lcg better then the rayspeed kit? and if so why?
Old School Stampede=FUN
hurley081182 is offline   Reply With Quote
Old 06-06-2005, 12:28 PM   #13796
@agower: I had a little trouble with shimming my diffs correctly. I had to reshim the diff after a few packs with a mod motor.
Now I'm using:
Front
one-way:
one shim on each side
bevel gear:
no shim
Rear:
diff:
bevel gear:
4 shims
Cheers
Chris
Old 06-06-2005, 01:12 PM   #13797
Send a message via AIM to aoizip
hurley081182:
well.. yeah... LCG is suppose be better then the rayspeed kit.
lower center gravity, more blue color(bulk head anyone ) and more.
did i just say that.. even mine is till on back order
but by how much... depends on your wallet...
a conversion kit cost almost as same as a new car kit.
my RS is doing me pretty good so far...
but my wallet couldnt take the bang till this month!
~Ming
*so you still up to buying my NIB RS kit?*
aoizip is offline   Reply With Quote
Old 06-06-2005, 01:26 PM   #13798
o yeah i do...lol....that is goin to be my backup car. thats funny im more worried about my that car then the car i will be racing with.
Old 06-06-2005, 02:13 PM   #13799
thanks,
are they the standard shims?
are you using graphite gears?
also
i am having trouble getting the rear smooth, it clicks (not outloud) you can just feel it when you turn it by hand but you can hear the binding if you spin it fast) at a certain point but not each time the gear goes round though like every 1 and a hlaf times it goes round. also the gear wobbles which is more than likely causing it. so how can i stop the wobble i have tried rebuilding the diff and have used a new gear but stil just as bad?
any help
Now I'm using:
Front
one-way:
bevel gear:
no shim
Rear:
diff:
bevel gear:
4 shims
Cheers
Chris
Old 06-06-2005, 02:42 PM   #13800
I have the same problem with my SDW
I m hoping that with a new graphite gear (better fit and finish) and some carbide ball its going to disapear
Make sure when you tighten the diff to do it progressevely, dont tighten it in 1 go, turn the diff a few times then carry on tightening it till its like you want
This will help to avoid building your diff out of round
Forgot: Shim your diff in order to have your gear a little more away from the bevel gear, the whole diff should have some play
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
